Go to Post There is more to our team than my hair, you know. :P - thefro526 [more]
Unread 20-01-2008, 16:23
penguain penguain is offline
AKA: Barry Preston
FRC #1997 (Stag Robotics)
penguain is an unknown quantity at this point
Robot Drive for 10 seconds
unsigned int timer = 0;
//Forward for 10 seconds
if(timer < 382){
pwm01 = pwm02 = 225;
timer++;
since the autonomus loops every 26.2ms
10 / 0.0262 = ~382
would this work to drive the robot forward for 10s/
thanks
2007 Greater Kansas City Regional Champions
2008 Greater Kansas City Regional Finalists
Unread 20-01-2008, 16:29
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Robot Drive for 10 seconds
I am not sure about the 382, but other than that it looks good. The only thing that I see is that on most robots the motors are faced different directions, so if that is your case, you just made your robot spin in a circle for 10 seconds. Something to look out for.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 20-01-2008, 16:36
AKA: Barry Preston
We're not sure how we did this, that code is right for drive straight
we first tried
pwm01 = 200;
pwm02 = 54;
and it just spun
Unread 20-01-2008, 16:50
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Have you got your IR board working yet, personally I think that having forward and stop functions mapped to two buttons is a better solution to driving forward a said time or distance then a solution like this. However this is a good start in the right direction for autonomous. If you need help with hybrid coding for the IR give a shout.
Unread 20-01-2008, 17:09
I'd suggest stopping the motors after the 10 seconds are up.
Unread 20-01-2008, 17:16
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
I'd also suggest slowing the motors down before you stop them, also speeding them up instead of just going from 127 to 255. If you don't do this and your robot is top heavy then you run the risk of tipping over. You can do this by modifying your counter slightly.
Sudocode:
pwm_2 = pwm_1;
static int counter = 0;
counter++;
if (counter <= 10)
pwm_1 = 137;
else if (counter > 10 && counter <= 20)
pwm_1 = 157;
etc...
We did this one year and it seemed to work pretty well. There might be a better way to do it, but this was simple and we wrote it in about 10 minutes.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 20-01-2008, 17:43
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
If you have access to encoders, you may want to have your robot drive a certain distance rather than for a certain length of time.
That way, you could write a function like Drive(distance, speed);
What place are we at? ... TODAI!
Unread 20-01-2008, 18:38
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
They most likely reversed the polarity of one motor when they connected it to a Victor. This has been a common practice for 364 for a number of years, so in fact, setting both motors to 254 will make it drive forward.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 20-01-2008, 20:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
One other thing to note is that your counter will need to be static.
where can I find the code for the first 15 seconds? CompMaster Programming 2 16-02-2005 16:23
counting in seconds for the autonomous mode?? Pattyta Programming 22 31-03-2004 12:55
pic: Four Seconds CD47-Bot Extra Discussion 9 30-03-2003 15:31
Numbers for thought: Are 10 black balls worth 30 seconds? archiver 2001 6 23-06-2002 22:42
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
