Go to Post User error is not the manufacturer's fault. - AdamHeard [more]
Unread 20-01-2008, 18:49
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: PWM Cables - Locking disconnects?
What exactly are you asking? Like how can you attach the cables to your GTSs (gear tooth sensors) and have them removable? If this is what you're asking, I would stick the male end of a pwm cable through the GTS, cut off the excess, bend the terminals to make it easier to solder, solder them, and then you have a regular PWM connection that is removable because the female end can easily be plugged in and unplugged.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Making PWM cables? HokieTutorunie Electrical 9 08-04-2007 12:29
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
