Go to Post Off season is a good way to go outside the district. - 346CADmen [more]
Unread 20-01-2008, 19:09
molly molly is offline
molly is an unknown quantity at this point
Wheel direct drive
Hi, I am new to this. Are there any disadvantages from driving the wheels directly from the motor/planetary gearbox - not through a spocket and chain.
thanks
Unread 20-01-2008, 19:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Wheel direct drive
Just t start, there are always advantages and disadvantages to every approach, in everything.
Anyway, just a few thoughts about direct drive:
1. Less control over the drive ratio, so you might not get the speed or power you want/need.
2. You have to locate the transmission and motor in a place that may not be convenient.
3. You do end up with less weight, which is a good thing, because you don't have sprockets and chain.
Don
Unread 20-01-2008, 19:42
Billfred's Avatar
Billfred Billfred is offline
I'll echo Don's comments about ratios; one of the reasons we're using chain in our setup is so that we have a fallback in case we completely misread the way the game would be played. Since we're Week 3 this year, we have a clue as to which way the game will be played. If we need to adjust our drive system, we just need to order some new sprockets, switch them out on Thursday at Chesapeake, and we're golden.
The other advantage to chain is that chain is an easy-to-fix place to have a drivetrain fail. Ideally you would have zero failures, but I'd much rather throw a chain than bend a shaft or otherwise bust a part.
Unread 20-01-2008, 20:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
On the other hand, a good direct drive shaft should be less likely to fail than a chain and sprocket setup.
Unread 20-01-2008, 20:33
BillB's Avatar
BillB BillB is offline
The Railgun of Mild Reason
AKA: Will Bellows
FRC #0540
BillB is an unknown quantity at this point
Send a message via AIM to BillB Send a message via MSN to BillB
Just one thing. Direct drive is a lot like driving your car around in only first gear. once you hit that point, it just will not go any faster. if you drive hard, it will reduce your motor and battery life as well. It works, but you have to do it right.
Unread 20-01-2008, 20:42
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
I have to agree with everyone. The only advantage i can think of is it's lighter. But you lose top end speed, and bat. life
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 20-01-2008, 20:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm confused.
I assume you're talking about direct driving a motor which is never a good idea.
Plenty of teams successfully direct drive their wheels, from a transmission.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-01-2008, 22:00
Jaybee1405
Posts: n/a
Our team was very tempted to go for DD this year because of all the chain problems we've been having in years past (they have been randomly falling off, for example: last year we had 8 idlers and 4 chain tensioners and we were still having probs)
Then we saw 2 disadvantages to DD and we decided to stick with chain:
1. Set gear ratio/speed from gearbox (with chain you can change sprockets)
2. If wheel is damaged, the shaft/gearbox will likely be damaged too (with chain, there will be no further damage than wheel)
Unread 20-01-2008, 22:05
That guy
AKA: Dennis
I remember you guys having probs last year.
Unread 20-01-2008, 22:36
Jaybee1405
Posts: n/a
haha yea, if you saw random chains lying in the middle of the playing field then you know who they belonged to.
We figured at least part of the problem was our axles (the 5 inch stainless threaded rod we used was only connected on one end of the frame, so our 6 in. IFI traction wheels were kinda like cantalevers)
Unread 20-01-2008, 23:15
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
We used direct drive last year. We had some custom hubs with key slots that fit inside of the IFI traction wheels we were using, which then slid right onto the shafts of the BaneBots gearboxes. On the other side, we put bearing blocks, which BaneBots sells for most of their gearboxes.
We had some major control problems last year, but they weren't related to the direct drive (as we discovered a few months ago). Everything else worked out pretty well, but we did have to take the gearboxes off every time something went wrong with the wheels (loose screws in the hubs, broken spacers, etc…), which meant taking screws out of hard-to-reach places.
We're going back to chain drive this year, since it allows us to manipulate our center of gravity much more easily.
Unread 21-01-2008, 07:43
Just to add a word of caution, direct drive will require some additional bearing support if you plan on adding wheels to the output shafts. Failure to provide adequate support will increase the bearing friction at the output of the transmission which results in high current and early failure of the bearings. Many teams that use chains forget this point as well. Unsupported side loads, transfer the load to the bearings and internal mechanics resulting in significant wear and friction. The friction is in turn reflected as high current in the drive motor which in turn causes excessive heat.
Unread 21-01-2008, 12:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I was just about the echo that sentiment Al. Usually to do a direct drive from the transmission to the wheel you need good pillow blocks built into the frame or mounted below it. The weight savings of the chain/sprockets becomes negligible at that point.
For 1885's design, I find that using the flat AM aluminum sprockets and #25 chain is a few ounces lighter and less expensive than buying pillow blocks.
GitHub
Unread 21-01-2008, 12:48
Deep Dark's Avatar
Deep Dark Deep Dark is offline
AKA: Dave Woods
FRC #2506 (Saber Robotics)
Deep Dark is on a distinguished road
Send a message via AIM to Deep Dark
Someone may have already posted something similar, but I personally like direct driving at least one wheel per drive side. That way, if the chain does come loose during a match, you aren't limping around on the field driving in circles. In this year's game, if this occurs near the lap readers, you can get docked points for driving in circles, depending on robot position.
My personal favorite design features a 6 wheel drive, with the center wheel directly driven with two sprockets, each going to their own respective outer drive wheels. That way, the whole robot consists of 4 chain loops, and even if all of the chain breaks or falls off the sprockets, you can still drive fine.
And a switching gear transmission helps with varying speeds, since many, like the AndyMark Supershifter, can have alternative gears that can be switched out to achieve different drive ratios. In many cases, this becomes faster than having to change sprockets on all 4 or 6 wheels, since you 'simply' need to remove, disassemble, and reassemble both drive transmissions.
Anyway, that's my $0.02
Dave Woods
Mechanical Engineer - Rexnord Conveying Equipment (New Product Development)
Alumni - Milwaukee School of Engineering (W-11
May '07 - present: Mentor/Co-Lead - F.R.C. Team 2506 Saber Robotics
May '06 - May '07: Mentor - F.R.C. Team 537 Charger Robotics
May '02 - May '06: Student - F.R.C. Team 537 Charger Robotics
Unread 22-01-2008, 19:16
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Direct Drive is awesome. You get great speed (we did at least). You don't have to worry about the chain breaking. And you will weigh less. Regardless, do not use direct drive unless you hate your designers. We did that last year and to put it simply, you have about 1" of clearence if you use a direct drive(assuming you don't offset your wheels). Though it works great, don't give your designers all headaches. I still remember the pain.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Direct Drive from Toughbox Gearbox diesel Technical Discussion 11 16-01-2008 04:30
Running Banebots Transmission in Direct Drive Marcel Motors 6 27-01-2007 22:20
Help! Direct Drive Issues roberthan Motors 16 21-09-2006 09:33
pic: 1097 Direct Drive 01 Anthony Kesich Robot Showcase 16 13-09-2005 22:33
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
