Go to Post Taking the time to do it right the first time is faster than rushing through it a third time. - EricVanWyk [more]
Unread 20-01-2008, 21:45
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Designing around the flag.
I was just curious as to how rule R17 is affecting your designs. Mainly the part about the top of the flag holder being a mandatory 51" off of the floor.
Unread 20-01-2008, 21:52
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Designing around the flag.
does it have to be 51" the entire match??? or just in starting config?
Unread 20-01-2008, 21:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Sounds to me like it needs to be there the entire match.
We did notice that it was rather convenient that our robot wants to be the same height as the flag holder needs to be.....
Unread 20-01-2008, 21:57
FRC #1360
lol it is rather convientent for us too, and we didn't even knoe about that rule lol.... I skipped the part about the flag
Unread 20-01-2008, 21:59
CraigHickman
Posts: n/a
Won't really be an issue for us. And besides, there's nothing that says the flag has to stay in the whole match...
Unread 20-01-2008, 22:01
MrForbes's Avatar
AKA: Jim
True, although it appears they are putting a cork in there to try to keep it in place.
Unread 20-01-2008, 22:06
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Flagholder height should definitely be constant the entire match. The rule specifies flag height in "playing configuration", which is elsewhere defined as any configuration you're in during the game, including transient states.
...The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in any PLAYING CONFIGURATION and the FLAG is in the flag holder, the FLAG is approximately vertical and the top of the FLAG is 75 inches above the floor. As the flag pole is approximately 36 inches long, that means the top of the flag holder must be 51 inches above the floor...
In answer to the original question, it should be pretty easy for our design.
Last edited by vhcook : 20-01-2008 at 22:09. Reason: intervening context changed meaning
Unread 20-01-2008, 22:18
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
It would be to your advantage to keep the flag in as the lap counter will also be attached to it via the rubber plug!
Unread 20-01-2008, 23:33
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
We ran into the flagholder problem this weekend. Let's just say our holder will be interesting.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 20-01-2008, 23:37
AdamHeard's Avatar
Lead Mentor
No problems here; If you've seen the 973 teasers you'd probably know why.
I'd definitely not take this rule lightly; losing your flag removes a scoring ability.
Unread 21-01-2008, 00:18
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
I should hope it doesn't. If the flag were the scoring object, it would have been spelled out in the rules that the flag is what counts when the robot goes around.
Judging by the way that scoring has worked in the past (2k6 especially), I wouldn't be surprised to see those poor referees having to count the laps manually.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Unread 21-01-2008, 01:52
reflion reflion is offline
Design Team 2204
FRC #2204 (Rambots)
reflion is an unknown quantity at this point
Whoa, never saw that rule...
but what stops you from just duct-taping it to a yardstick? Will it really cause you guys design problems?
Then again, it's easy for our team because we're a rolling box again, so...
Unread 21-01-2008, 01:55
Duct tape is illegal... Zip ties, on the other hand, are not.
Unread 21-01-2008, 09:53
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
That is wrong. Please be careful about making up rules that don't exist.
Duct tape is not illegal. I have read through the rules a few times () and I can't find any rule that prohibits it. Duct tape is treated like any other adhesive-backed tape (see Rule <R38>).
-dave
Unread 21-01-2008, 10:31
Duct tape is illegal as a fastener. That's because it's an adhesive-backed tape, not because it's "duct tape".
Flag, Flag Holder vs Trackballs Swampdude Rules/Strategy 29 09-03-2008 09:17
Designing the Robot Dan Petrovic Team Organization 15 23-09-2006 22:14
[OCCRA]: Rules Question: Can the flag move the arrow? wbhsAndy OCCRA Q&A 1 27-10-2004 11:01
Capture The Flag Trashed20 Championship Event 16 22-04-2002 08:57
Capture the Flag 238junior General Forum 0 09-04-2002 21:49
