Go to Post If only all this food for thought happening in this thread could somehow be funneled into solving world hunger... - artdutra04 [more]
Unread 19-01-2008, 00:57
Aren_Hill's Avatar
Build Nifty Things
Re: pic: DeWalt carnage
So as referenced in the NothingButDewalt whitepaper to interface a fischer price motor you must order the motor housing, except when i enter the part number for the housing into dewaltservicenet.com it doesn't recognize it. any ideas? or where to quickly get the whole drill minus battery and charger
A guy who likes robots.
Unread 19-01-2008, 10:12
MikeZ MikeZ is offline
FRC #0624 (CRyptonite)
MikeZ has a spectacular aura aboutMikeZ has a spectacular aura about
Originally Posted by richardmcc2 View Post
We are doing the same thing This will be our first year using Dewalts on the competition robot, but I did personally assemble 4 CIM/Dewalts (DC980) for an off season project last year. We have 4 DC940's that should arrive Monday, but I was hoping to get a head start on making some of the parts (top hat, servo plate, piano wire piece, and CIM mount). How different is the new model? Could anyone post or PM me dimensions or changes that need to be made in order to work with the new model so our team could get started this weekend?
Richard
The primary difference in dimension for us is the hole pattern. In DWG NO. 1 (Chiaphua Plate) from the NBD paper, we replaced the 0.6875" dimension with 0.745" and the 1.055" dimension with 1.110". Since this hole pattern is larger than the DC980 model, the plate needs to have a larger OD. We used 3". The servo plate will need a bit of adjusting as well to accomodate the larger hole pattern.
We do not use the method of boring out the sun gear as described in the NBD Paper, so I cannot speak to any mods needed on the transmisison case. Last year we successfully used the StevenB method of using a "sun gear adaprter" described in this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=50091
It worked beautifully for us last year.
Hope this helps you get started. Let me know if you need more info.
Mike Zanghi
Lead Mentor
Team 624 CRyptonite Robotics
Unread 19-01-2008, 10:55
Originally Posted by Tom Line View Post
For all you folks looking for just the transmission, check here:
http://www.ereplacementparts.com/dew...3b6 3ef475e09
Of course to be able to use the transmission, per the NBD white paper, other drill components are needed (clamshell, spindle, spindle housing, cap) As a comparision, using the DC940 model, the necessary components for 4 complete transmissions plus shipping from www.ereplacementparts.com is $307, vs $302 from www.dewaltservicenet.com vs $239 from a source who sells the whole drill without batteries and chargers. Besides cheaper, it is fun to have the students learn to disassemble, modify, and otherwise create DeWalt carnage.
Mike Zanghi
Lead Mentor
Unread 19-01-2008, 11:17
PDF32100 PDF32100 is offline
AKA: Pedro
FRC #0714 (SUPER PANTHERS)
Team Role: Driver
PDF32100 has a spectacular aura aboutPDF32100 has a spectacular aura aboutPDF32100 has a spectacular aura about
Send a message via AIM to PDF32100 Send a message via MSN to PDF32100
i cant wait till u guys are in need of a drill....
Unread 19-01-2008, 23:35
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Originally Posted by MikeZ View Post
Richard
Mike Zanghi
Lead Mentor
Thanks for the help Mike.....I had one other question for you or anyone else....what are the most common ways of mounting the gearboxes? The only way I've seen is using the aluminum shaft collars from mcmaster, and welding them to the frame. We are using the kit frame this year and don't have welding capabilities. Has anyone ever used Dewalts for a drive system on the KOP frame?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 20-01-2008, 14:33
Richard
Here is a link showing how we mounted the Dewalts on our 2007 robot kit frame without welding. We tapped and threaded the lower half of the collar clamp, and designed the CIM plate to serve as a mount as well. We machined and bolted a "drivetrain pan" to the kit frame. The lower half of the collar clamp and CIM plate/mount were then secured to the drivetrain pan with bolts from underneath. From the pic you can also see how we used some sliders to adjust chain tension.
http://www.chiefdelphi.com/media/photos/29730
Mike Zanghi
FIRST Team 624
CRyptonite Robotics
Unread 20-01-2008, 14:45
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by tacopaco789 View Post
and the large metal front where the bit would go
That's called the "Chuck".
Good job with the trannies though!
Unread 20-01-2008, 22:14
Engineering Mentor
Thanks for posting the photo! Hopefully this will give our design team a little inspiration.
pic: Canadian Carnage Koko Ed Extra Discussion 7 26-09-2006 17:04
pic: 862: Camera Carnage 2 Joe J. Extra Discussion 2 11-03-2006 22:40
pic: FRC 488 -- Poof Ball Carnage Madison Extra Discussion 2 06-03-2006 19:01
rObO cArNaGe pyro20911d General Forum 6 16-02-2006 00:17
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
