Go to Post The honor from any given job is not so much what you are doing, but how you do it; the hardest working garbage man deserves more honor then the laziest super hero. - Josh Hambright [more]
Unread 19-01-2008, 23:23
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
399's scissor lift pics.
Dun dun dun...
I know pictures of it upright would make everyone more happy, but when we were running it as such I didn't think to take pictures...
It works consistently, with weight... these pictures are from a few days ago, and today we mounted a larger actuator (it's going to have 2, 2 inch bore actuators on it) and connected the two sides of this together (one actuator per side). next step they will be on the robot.
I'm waiting for the problems.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 19-01-2008, 23:49
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
Re: 399's scissor lift pics.
Way to go. We'll stop by and check it out. I hope you get it to work.
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 20-01-2008, 23:18
zacattack's Avatar
zacattack zacattack is offline
AKA: Zach Fisher
FRC #1724 (Weber Fever)
zacattack has a spectacular aura aboutzacattack has a spectacular aura aboutzacattack has a spectacular aura about
I hope that you use two scissor lifts, or else it will suck.
Unread 20-01-2008, 23:23
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
That appeared to be their plan in another thread.
Looks nice. How is the piston/lift attatched to the chassis?
Unread 21-01-2008, 09:44
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
It looks like it could be flimsy, I hope you guys will brace it somehow
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 22-01-2008, 14:32
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Remember that your scissor lift just created a BUNCH of pinch points. I hope you guys are constructing some type of shield to cover them, otherwise you might not make it past inspection. I know this rule gave teams a hard time last year with the scissor lift idea:
Originally Posted by <R05>
Exterior or exposed surfaces on the ROBOT shall not present undue hazards to the team members, event staff or GAME PIECES. Reasonable efforts must be taken to remove, mitigate, or shield any sharp edges, pinch points, entanglement hazards, projectiles, extreme visual/audio emitters, etc. from the exterior of the ROBOT. All points and corners that would be commonly expected to contact a TRACKBALL should have a minimum radius of 0.125 inches to avoid becoming a snag/puncture hazard. All edges that would be commonly expected to contact a TRACKBALL should have a minimum radius of 0.030 inches. All of these potential hazards will be carefully inspected.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 22-01-2008, 16:05
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
Looks great, but just one question: Any reason you chose to use six diamonds on your scissors?
Unread 22-01-2008, 22:22
.999~=1
Zach: We definitely will have two, one on the left, and one on the right of the robot.
To attach to the chassis, it's kind of hard to see, but there are rollers on one of the legs, which will be encased and that casing is mounted to the chassis. The other leg will be fixed, and it will be like this on both sides... it's kind of hard to explain. That actuator will also have a little something to keep it stable, but it's only hard mounted to the lift.
As for it being flimsy... you'll see. =)
Justin: Thanks, we plan to have a cover of some sort. also there are hard mounts so it doesn't collapse all the way, but I know they will still be treated as pinch points, and will be taken care of accordingly.
Finally, the six diamonds are because that's what gave us the required movement to use an actuator where we wanted. We had to choose between 24 inches and 12, with 24, 4 diamonds would have worked, but they extended very thin and we were worried about stability. 5 gave us a distance of 18 inches..... and in the end 6 worked well, so it's what we used. Heh.
phew.
Unread 22-01-2008, 22:33
D_Price's Avatar
D_Price D_Price is online now
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
Hey ..umm yeah we did this idea last year and it backfired on us.... and yeah since the trackball weighs 10 pounds you are going to need to counteract the weight with another force.
Unread 22-01-2008, 22:36
.999~=1
How did it backfire? did you mount the actuators the same way? =/ What problems did you run into?
And I don't quite follow what you mean by counteract the weight, we're lifting straight up over the robot, and those actuators have more than enough force to lift what we're planning to.
Unread 22-01-2008, 22:39
Jaybee1405
Posts: n/a
I think that you may have problems getting the trackball up onto the platform. Pulling 10lb straight up is one thing. Pulling it at an angle as severe as you have it is another.
Unread 22-01-2008, 22:42
.999~=1
... I'm not quite following! =/ We plan to lift the ball straight up, not at any angle, and then it will roll off the front of a cradle that it will sit in..
Unread 22-01-2008, 22:53
Jaybee1405
Posts: n/a
I mean the part where you lift the ball off the ground onto your platform.
Or is it just going to sit in that front cradle the whole time and never go on the scissor platform?
Unread 22-01-2008, 22:58
.999~=1
Ohh, I see what you're saying. Our arms can lift the ball, we've done testing, to get it onto the platform. We are using a 6 inch diameter gear for leverage, and mounting two actuators (one on the left, one on the right) to pull chain mounted onto the gears 120 degrees around. It's rather clever...
I'll have more pictures up when it gets closer to being done. =)
Unread 22-01-2008, 22:59
Jaybee1405
Posts: n/a
ok sounds like a plan!
Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs AdamC Technical Discussion 31 20-01-2008 18:49
399's ramp release. Brad Voracek Robot Showcase 14 04-02-2007 22:40
Scissor Design Tom McCurdy Technical Discussion 16 03-02-2005 09:19
Image Discuss: Team 30 Scissor lift raised CD47-Bot Extra Discussion 5 02-02-2003 00:34
