Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Unread 21-01-2008, 02:36
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
SONAR sensors for collision avoidance
Hi, I'm currently searching for a SONAR sensor to use for collision avoidance on our bot. An example sensor I am looking at is at the following link.
http://www.robotshop.ca/home/supplie...der-srf05.html
Do any of you have any experience using such a sensor? Is there any example code?
Thanks,
Windel
Unread 21-01-2008, 08:49
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: SONAR sensors for collision avoidance
No sonar here, but several times Team 95 has implemented a "virtual bumper" using infrared sensors (if range<some value, apply a heavy damping function on the drive train)
Unread 21-01-2008, 17:03
FRC #2477
Thanks for your response! Hmm damping function. What do you mean by this? is this a mathematical damping function?
Unread 21-01-2008, 18:49
kaszeta's Avatar
Exactly. Ours was something like
(a) if object is within 12", only drive the motors at 2/3 the commanded speed
(b) if object is within 6", only drive the motors at 1/3 the commanded speed
Using this approach, we could run out robot at full speed towards a box on the field, and it would only lightly bump it.
Unread 21-01-2008, 18:57
DonRotolo's Avatar
Back to humble
FRC #0832
There is also some useful info in this thread.
I have played with the $30 Maxbotix sensor with a Vex bot, and I am very impressed with its range, accuracy, ease of interfacing and cost/value ratio. I am pushing the team to use them for this year's Hybrid mode.
Don
Ultrasonic rangers for obstacle avoidance pogenwurst Programming 5 11-01-2008 19:22
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
Collision avoidance during autonomous Andrew Schuetze Programming 5 17-01-2006 13:24
Collision Detection in Inventor? jlewellen Inventor 2 06-01-2005 21:29
Grady personal injury avoidance tip #2 archiver 2001 27 24-06-2002 00:05
