Go to Post Overall, I thought FIRST did a great job with the rules this year - very simple and very clear for the most part. However, something is always going to fall through the cracks (and I don't mean that in a bad way - people need to know that it's practically impossible to do something perfectly). - Chris Hibner [more]
Unread 21-01-2008, 03:27
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: pic: 675 not-so-teaser.
Originally Posted by Gabe View Post
I like it for its simplicity that makes it elegant. The use of slotted aluminum for spacing the sheets is a very good idea.
That's 80/20 you're thinking of. Huzzah useful stuff! (although it weighs a little bit right now ~55lbs for driving spec)
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 22-01-2008, 13:12
Otaku's Avatar
AKA: Michael Baker
Forgot to talk a bit about the simplicity: Why over-engineer a chassis when we know it works? It's real similar to last year, except stronger (egads, that's a feat!). The extrusion at the back gives us a common mounting point for any and all manipulators (interchangeability egads) as well as simplicity in dismantling the chassis (to get the back panel off, 8 bolts. to get the sides off, 8 bolts & 2 shaft collars. To get the center off, 4 bolts. All of this can be done pretty quickly, too.
Cheers,
MBaker (AKA Otaku)
Unread 22-01-2008, 14:20
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Nice! As of today we're at the same exact point you are with your competition chassis. Hopefully we'll be driving around tonight.
Our chassis is built around the same purpose. The whole thing is only held together with 26 bolts total. We can completely disassemble (and we have twice since last Wednesday) the chassis in about 10 minutes and assemble in just about the same amount of time.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 22-01-2008, 18:45
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
I cant believe how well we are doing this year.
I cant believe we actually have time to build two robots
whether or not we use both the idea still is there and our electronics wow Brian look awesome
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 24-01-2008, 14:49
Otaku's Avatar
AKA: Michael Baker
Stokedalicious
Got the 'bot assembled, waiting on manipulators
chassis is complete, electronics, programmed and driving.
pic: Team 1676 not-so-teaser DonRotolo Extra Discussion 2 20-01-2008 19:50
pic: 675 Teaser #1 Otaku Extra Discussion 15 11-01-2008 07:29
675 Teaser #2 MikeJ675 Robot Showcase 10 17-04-2007 22:42
pic: Team 125 Teaser #3 (not so blurry) Daniel Brim Robot Showcase 33 15-02-2007 12:51
pic: Probably not a teaser Kris Verdeyen Extra Discussion 8 14-01-2007 20:35
