Go to Post I hate having to wear official pants. - Cothron Theiss [more]
Unread 19-01-2008, 10:10
Vanquish Vanquish is offline
Rookie Year: 1980
Vanquish is an unknown quantity at this point
Inventor Download
Were having trouble downloading inventor from the autodesk.com/firstbase website. Any ideas other than try again in a while?
Unread 19-01-2008, 17:14
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
Re: Inventor Download
I haven't tried this yet, but will later this weekend because we're having problems with the d/l as well. If you find a torrent or something of the same program that you would get form their website and download that and enter the serial number that they give you for the student version that might work, but its just a guess. I'm also assuming that that is legal too. It seems like it would be because you are getting the copy you own because it's 1 of the 10 you get for free, and that serial number would be used up once the program is registered. If anyone knows the legality for sure please post so i know if i should do it/suggest it.
Unread 19-01-2008, 18:04
BaldGuy BaldGuy is offline
AKA: Harry
FRC #1518 (Palmyra-Macedon Raiders; previously known as Ulterior Motive)
BaldGuy is an unknown quantity at this point
I just this moment finished insatlling it but had to do it using the 4 zip files- I then had to extract all the contents of each zip file into one central file, and then run setup.
Bring along the First Rule Book, you can read it from cover to cover while all this is taking place.
I am having problems registering it, but it gives you 30 days to do that.
Good Luck.
2007 FLR- Finalist (with 340 & 354)
2011 FLR Champions (with 217 & 2056)
Unread 19-01-2008, 19:22
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
I know I may have mentioned this before, but I strongly recommend using the FirstBase downloader tool. Especially since it's a piece of software Autodesk created just for FIRST teams.
Just my two cents.
Unread 21-01-2008, 08:23
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
The most common problem I see with people trying to register is they do not realize that the registration site is a different site that requires creation of a new username and password account (follow the instructions for allowable passwords).
An alternative site is http://engineersrule.org
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 21-01-2008, 11:49
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
i had trouble too but it worked when i downloaded 4 separate files
you download and unzip them put the contents all in a folder the run setup
Inventor 2008 files in Inventor 11 pufame CAD 1 18-09-2007 19:19
Inventor 2008 // last thread EVER about chains in Inventor? Dan Zollman Inventor 10 10-07-2007 20:01
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
Inventor Download HELP!!!!!!!!!!!!!!!!!!!!!! RobotPirate 3D Animation and Competition 6 20-01-2007 23:53
Complete Playing Feild in Inventor Ready for Download Robert Thacker- Inventor 4 19-02-2006 14:06
