Go to Post Also you NEVER need to apologize for asking questions. Asking questions is how you learn. - akoscielski3 [more]
Unread 21-01-2008, 08:56
JohnStewart JohnStewart is offline
JohnStewart is an unknown quantity at this point
mplink errors in eclipse
I tried using eclipse ide for code development. But I get a funny error during the mplink step. I tried the same mplink command from a shell and that works fine. Why does eclipse cause this problem?
Here's the build error from eclipse.
Building target: BallBot_2008.hex
Invoking: MPLINK Linker
mplink "..\18F8722.lkr" /a INHX32 /w /m FRCMapfile.map /o"BallBot_2008.hex" ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /l"C:\mcc18\lib" ..\FRC_library_8722.lib
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - unrecognized input: C:/msys/1.0/a
Errors : 1
make: *** [BallBot_2008.hex] Error 1
Visual Studio C18/MPLINK build rules >>>HERE<<< itsnotabigtruck Programming 4 03-03-2008 07:48
Build problems: MPLink 4.15 Linker... help? Trav-O Programming 2 12-01-2008 14:26
Mplink error jimmyrock88 Programming 2 14-11-2007 15:50
"Full screen mode" in Eclipse/Easy Eclipse Kelly Programming 0 15-07-2007 16:37
MPLink Error cloudago Programming 2 01-02-2005 23:00
