Go to Post when I was a ball setter at PARC one year (6th grade?). As soon as I saw what High school students could do with thier own two hands and how they mingled with industry, I knew, at that moment, it was for me. - henryBsick [more]
Unread 19-01-2008, 12:14
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
Parallax and Maxbotix ultrasonic sensors
Does anyone know if there are device drivers for the Parallax Ping))) and the Maxbotix EZx written for WPIlib? I've looked at the SONAR driver and Qbranch's Ping))) code, but it's based off the default IFI code, and I have no idea any of it works.
We're using a makefile with mcc18 under Wine.
Unread 21-01-2008, 09:01
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Parallax and Maxbotix ultrasonic sensors
I was just reading the spec sheet for the Maxbotix EZ1 sensor. It looks like one of it's outputs is analog. So you should be able to connect it directly to an analog input and read range values. The datasheet lists the output at about 9.8mV/inch, so with some simple scaling you could convert the 0-1023 analog input value directly to inches. It also looks like if you use the pulse output it may be directly compatible with the existing driver, but I haven't tested it.
The sensor looks really good - I'm going to order one to play with. More news as it happens.
The Parallax sensor uses timing much like the supported SRF04 (or Vex) sensor, the problem is it does the trigger (digital output) and echo (interrupt) on the same pin. The driver would have to be modified slightly to flip the pin from an output to an input to make it work.
Brad Miller
Robotics Resource Center
Unread 21-01-2008, 10:41
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We used the Maxbotics EZ-1 last season using analog with good results.
The formula we used:
Mv =( (adc * 5000) / 1024 )
Inches = Mv / 10
Gave use the distance in inches for the version that used 10mV per inch.
It was changed from 10mV to 9.8mV
So in your case you might want to try:
Inches = Mv * 10 / 98
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 21-01-2008, 15:56
Thanks for the tips regarding the Maxbotix EZ sensors (we'll be using the EZ0).
We actually got the Parallax Ping))) working with the built-in WPIlib functions. The only modification was to convert the two ends of a PWM Y-connector to female so we could plug them into two digital in/outs. Worked like a charm!
Unread 20-02-2008, 00:39
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Inches = Mv / 10
I was just looking at the datasheet for the newer versions with 9.8 mV / in. scaling, and it does not specify "9.8" but rather "~9.8". The exact scaling factor for 5V power is (5000 / 512) mV / in.
It shouldn't make much of a difference, but that sort of thing bothers me.
Unread 20-02-2008, 14:34
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
We just divide the analog output by 2 to get the reading in inches.
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
can we use ultrasonic sensors? GMKlenklen Electrical 20 15-01-2007 14:34
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
Programming the parallax PING))) Ultrasonic Sensor edman Programming 3 18-02-2006 23:37
Programming Parallax Ultrasonic Rangefinder edman Programming 2 17-02-2006 08:35
