Re: Parallax and Maxbotix ultrasonic sensors
We used the Maxbotics EZ-1 last season using analog with good results.
The formula we used: Mv =( (adc * 5000) / 1024 ) Inches = Mv / 10 Gave use the distance in inches for the version that used 10mV per inch. It was changed from 10mV to 9.8mV So in your case you might want to try: Mv =( (adc * 5000) / 1024 ) Inches = Mv * 10 / 98 |
Thanks for the tips regarding the Maxbotix EZ sensors (we'll be using the EZ0).
We actually got the Parallax Ping))) working with the built-in WPIlib functions. The only modification was to convert the two ends of a PWM Y-connector to female so we could plug them into two digital in/outs. Worked like a charm! ![]() |
It shouldn't make much of a difference, but that sort of thing bothers me. |
We just divide the analog output by 2 to get the reading in inches.
| Ultrasonic range sensors for Vex Robot | OneCoolDude | Programming | 1 | 01-12-2007 09:22 |
| can we use ultrasonic sensors? | GMKlenklen | Electrical | 20 | 15-01-2007 14:34 |
| Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program | EHaskins | Programming | 8 | 22-05-2006 12:08 |
| Programming the parallax PING))) Ultrasonic Sensor | edman | Programming | 3 | 18-02-2006 23:37 |
| Programming Parallax Ultrasonic Rangefinder | edman | Programming | 2 | 17-02-2006 08:35 |
