Go to Post ...I pretty much got the impression that the balls are actually very small, cuddly landmines. - Gui Cavalcanti [more]
Unread 20-01-2008, 22:57
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Timers causing code errors?
Hey, i implemented a simple timer that dings every 25ms, for the purposes of differentiating an encoder signal. Before i implemented it, the code was working fine, but after i did i get code errors (red light of doom) that seem to be resolved by a simple press of the reset button... and then it doesnt return until i shut the robot down completely.
any suggestions/thoughts?
yes, i have downloaded master code v15 (i think its 15) to the robot and master controller.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 20-01-2008, 23:39
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Timers causing code errors?
Are you using a hardware timer? If so, which timer? Timer 0 is used by the Generate_PWMs() function in the standard IFI librarys. Trying to use it for your timer will play heck with things for certain.
If not, have you implemented your interrupt routine correctly? Are you not clearing the interrupts flag? Are you staying in the interrupt routine too long? Are you possibly corrupting some of your memory with your interrupt routine?
Unread 21-01-2008, 04:34
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
im pretty sure im using timer 1, and im also certain that im not corrupting memory or taking too much time... i think.
RPI 2012
BREAKAWAY
Unread 21-01-2008, 12:17
Kevin Watson's Avatar
La Cañada High School
FRC #2429
My vote would be that you're not clearing the interrupt flag in the ISR.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2008, 19:40
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Check and make sure "#pragma ... save=" is saving all of the required registers. Which ones are dependent upon your interrupt service routine code and what is used.
Posting the #pragma and the ISR code pertaining to the timer would help.
Unread 21-01-2008, 19:59
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
We implemented the interrupt-based timer described in the IFI white paper.
It has worked fine for us without errors.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 22-01-2008, 02:10
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
ok, ill post it next time i get my hands on the code (tomorrow probably)
and i think i am clearing the flag... the error only occurs when we do a hard reset of the robot, and a soft reset fixes it.
RPI 2012
BREAKAWAY
Code error causing robot to go into programming mode. MJD Programming 14 30-10-2007 14:21
Code Errors With "Bells and Whistles" Ryan O Programming 2 31-01-2006 19:29
Timers MarkVH Programming 1 13-02-2005 11:30
Timers ? Gal Longin Programming 5 12-02-2005 06:15
Timers bludstayne Programming 1 19-01-2004 19:25
