Go to Post Just wondering what types of food you have been living off of while working on your robot? Our team has had pizza almost 3-4 times a week or more. Just wondering. SGS DRAGONS - sgsdragons [more]
Unread 21-01-2008, 12:33
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Pnuematic Claw
Hey all, our team has decided to try to make a pnuematic claw this year
I have a few questions:
a. what do I use to mount my cylinders so that they can pivot
b. what should be on the tip of my piston so that when it fires out, it wont directly hit the claw and get distorted
thank you!
Unread 21-01-2008, 14:28
RoboGeek99's Avatar
RoboGeek99 RoboGeek99 is offline
FRC #2582 (Panther Bots)
RoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really nice
Re: Pnuematic Claw
Well we're a rookie team too and how we are trying to mount ours is with a sort of pivot on both ends of the cylinders sorry i cant be of more help because our arm is still being sketches out so we dont even know if it will work yet but still its and idea.
Unread 21-01-2008, 14:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Pnuematic Claw
thank you!
A: Depending on which size you ordered you will have a pin or a pivot hole at the base of the cylinder. Download the Bimba catalog, it will show you all of the dimensions and mount types.
B: I don't really understand your question. Do you have more details? The cylinder rod has a threaded end that you attach things too.
Unread 21-01-2008, 14:43
Given To Fly's Avatar
Given To Fly Given To Fly is offline
Pearl Jam man
AKA: Tony Frates
FRC #2761 (Iron Horse)
Given To Fly will become famous soon enough
Re: Pnuematic Claw
Be sure to allow your pnuematic claw to disengage once the match is complete. Set up crew must be able to easily remove a trackball from your claw once the match is over without your robot being powered back up. see rule, <G45>
Good luck with the build.
Unread 21-01-2008, 14:44
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Pnuematic Claw
The piston will come with some mounting hardware including a clevis that screws onto the end of the threaded piston shaft. That allows you to mount the "moving" end of your piston with either a pin/bolt/bailing wire/etc. as a pivot. The body of the piston can be mounted in a couple ways. The piston will come with brackets to mount the piston using the pin on the end of the body. The pin at the end of the body (only on the 3/4" and 1.5" bore pistons, I believe the 2" bore has bushings) can be pressed out and a bolt can be used in it's place. There are also threads on the body of the piston to allow for mounting of the body of the piston without a pivot.
There might be a couple things I've missed, I'm sure others will chime in.
As a side note, look to protect the smaller bore pistons while in the extended position to prevent irreparable damage during competition. (These things bend very easily when whacked into hard objects.)
701's 4" pnuematic robotic canon Doug G Chit-Chat 2 04-10-2005 21:32
pic: The shadow claw--claw bradleym1559 Robot Showcase 20 09-03-2005 13:48
Pnuematic programming f22flyboy Pneumatics 4 11-11-2002 14:37
Pnuematic programming f22flyboy Programming 0 07-11-2002 11:19
DOES ANYONE HAVE PNUEMATIC RELAY PROBLEMS? archiver 2001 0 24-06-2002 00:30
