Help with programing saitekx36f joystick and throttle
I am having a hard time trying to find what the pins do for the controller. I sent an e-mail to their tech support but that doesn't work anyone where i can find this information that i seek.
Re: Help with programing saitekx36f joystick and throttle
If you're lazy you could just print out all input from the port and try and figure out what it's giving you. Otherwise, I have no idea.
Either print values for each variable (p1_x, p1_y, etc) to the screen and see what changes as you push each joystick button or get a multimeter and measure voltage at each pin.
Thanks you all i will try it but we are closing up shop today.
The only way I know of to connect it to an IFI Operator Interface joystick port (without ripping the guts out of the joystick and rewiring it as a simpler 15-pin game port device) is to also use an X36T USB throttle control and a Chicklet USB-to-joystick-port converter. You might get lucky and find that it works as an Aviator or ST290, but you more likely will have to pay for the Chicklet to be reprogrammed to recognize the X36 system. |
| NEED PROGRAMMER TO HELP WITH PROGRAMING | Reaper40 | Programming | 4 | 02-02-2007 17:31 |
| Help with joystick | lightning_blast | Programming | 2 | 12-02-2006 22:25 |
| Programing a joystick | Justin_302 | Programming | 2 | 21-03-2005 22:45 |
| Help with Joystick Axes and Sensitivity | bglass | Programming | 6 | 06-02-2005 14:01 |
| help with programing banner senor. | incognito_NICK | Programming | 2 | 17-11-2004 06:51 |
