Go to Post Throw the programmers (or freshmen with duct tape depending on the state of your robot) in the trailer with the robot for the ride between events. Problem solved. :D - ASD20 [more]
Unread 21-01-2008, 15:43
Re: General Question About Pneumatics
Originally Posted by itsme View Post
We put teflon and now it's fine (just a tiny bit air running out, but not really significant). But if we screwed a bit the valve (the inner screw-nut) did it change the calibration?
If you say there is already a default relief valve on the compressor, is it a must to put another relief valve in the circuit?
The one on the compressor is to ensure that you don't go over a safe pressure. The manual one (with that black valve) allows you to drain the air manually. You probably want that on so you don't have to run a cylinder multiple times to drain the system.
I honestly don't know about the 125 psi valve.
Unread 21-01-2008, 15:49
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Yeah, I already put that manual valve (I connected a circuit almost identical to the one in the manual)
But what about the so called relief valve on the KOP checklist?
2007 Israel Regional GM/Technion Rookie Allstars
Participated in 2007 Atlanta World Championships (Newton Division)
Unread 21-01-2008, 15:59
Ohhh you meant the regulator?
I put the regulator and calibrated it to be at maximum of 60 PSI (as said in the rules).
I'm talking about the relief valve (the one with the blue spring inside it).
EDIT
Or did you mean the black manual valve?
And what about the so called relief valve on the KOP checklist?
The "relief valve" from the checklist is the one that you cannot change. It must go on the compressor. <R95>.
The black manual valve also must be in the system.
<R97> The Parker pressure vent valve must be connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure. The valve must be placed on the ROBOT so that it is visible and easily accessible.
I don't know which relief valve has a blue spring inside it. Might be one of the regulators or gauges.
Unread 21-01-2008, 16:06
FRC #2217 (FOMH)
So if I screwed a bit the inner nut-screw did it change it?
What should I do to change it back??
Unread 21-01-2008, 16:07
I don't know the answer to either question.
Unread 23-01-2008, 10:51
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
what are the exact rules on amount of pressure the system can have. i was going through the robot rules and i found we can have a limit of 120psi, but in the pneumatics manual its says the regulator has a limit of 60 psi.
is it 120 psi in the tanks and only 60psi elsewhere?
how does that work?
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 23-01-2008, 11:17
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That is correct. You have the compressor, pressure switch, tanks, relief valve, high side pressure gage, and manual release valve all connected together before the regulator. This part of the system is at 120 psi maximum.
After the regulator, you have the second pressure gage, the solenoid valves, and the pneumatic cylinders (and the second pressure regulator if you so desire). This part of the system is at 60 psi maximum.
Need Help With General Pneumatics Ryan O Programming 7 24-01-2007 21:31
General question about the robot controller itsme Technical Discussion 6 14-01-2007 15:33
General programming question mikesown Programming 1 07-02-2005 16:09
General Pneumatics Drok00 Pneumatics 8 11-01-2005 23:35
Question about the animation in general... Devil's Kid 3D Animation and Competition 5 22-01-2002 12:34
