Go to Post Thanks for the wishes of luck. We try to minimize its importance, but having it on our side is never a bad thing. - Madison [more]
Unread 21-01-2008, 16:32
etdeshon's Avatar
etdeshon etdeshon is offline
Ethan (programmer)
AKA: Ethan DeShon
FRC #1641 (Mojave Robotics Team)
etdeshon is an unknown quantity at this point
Send a message via AIM to etdeshon Send a message via Yahoo to etdeshon
Exclamation Programming Issues
hey guys, im having some issues with trying to have our autonomous mode run, or hybrid mode. im not sure how to do it so im asking how to. anyone know how to activate hybrid mode through the programming or something? we are just trying to run some motors with the remote. can anyone help?
Unread 21-01-2008, 16:36
Back after 4 years off
FRC #5279
Re: Programming Issues
You put your code in the Autonomous Routines section of User_Routines_Fast.c to activate this code you need to build a dongle that connects to the competition port. A switch between pins 5 and 8 will enable and disable autonomous. A switch between pins 6 and 8 enables and disables the whole robot. If you have more questions just ask.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 21-01-2008, 16:49
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 21-01-2008, 17:26
etdeshon's Avatar
Ethan (programmer)
AKA: Ethan DeShon
thanks for the help, ill try it out and if it doesnt work ill tell about it and try to figure it out again.
Unread 21-01-2008, 17:38
etdeshon's Avatar
Ethan (programmer)
AKA: Ethan DeShon
ok next question..... im kinda new at the autonomous thing so... we've never done this before either. what wires do i need for the switch... i know i need the ground one. what other wires? ive got green, blue, grey, white, red, orange, brown, yellow, and thats it....
Unread 21-01-2008, 17:59
FRC #5279
Colors don't matter much but I would use red from the pin to the switch and black from the switch to ground.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
CPU issues Windward Electrical 3 01-02-2007 22:49
Compiler Issues SavannahStasher Programming 5 28-01-2006 16:33
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Weight Issues AdamL118 Technical Discussion 19 11-02-2004 20:52
