Go to Post FIRST is all about working with others. - briholton [more]
Unread 21-01-2008, 17:38
etdeshon's Avatar
etdeshon etdeshon is offline
Ethan (programmer)
AKA: Ethan DeShon
FRC #1641 (Mojave Robotics Team)
etdeshon is an unknown quantity at this point
Send a message via AIM to etdeshon Send a message via Yahoo to etdeshon
Re: Programming Issues
Originally Posted by JamesBrown View Post
You put your code in the Autonomous Routines section of User_Routines_Fast.c to activate this code you need to build a dongle that connects to the competition port. A switch between pins 5 and 8 will enable and disable autonomous. A switch between pins 6 and 8 enables and disables the whole robot. If you have more questions just ask.
ok next question..... im kinda new at the autonomous thing so... we've never done this before either. what wires do i need for the switch... i know i need the ground one. what other wires? ive got green, blue, grey, white, red, orange, brown, yellow, and thats it....
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
CPU issues Windward Electrical 3 01-02-2007 22:49
Compiler Issues SavannahStasher Programming 5 28-01-2006 16:33
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Weight Issues AdamL118 Technical Discussion 19 11-02-2004 20:52
