Go to Post Incidentally, this is a good example of why lawyering the FIRST rules is good practice for the real world. By critically analyzing FIRST's errors, you practice for the day when you need to critically analyze legislators' errors (and deliberate trickery). - Tristan Lall [more]
Unread 21-01-2008, 17:28
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Using Magnets
Our team wants to use a limit sensor to calculate when we want a motor to start and stop. The one problem with this is the limit sensor would be destroyed by a fast moving piece of medal. We want to use a magnetic proximity switch(or something like that that triggers a button via a magnet) but we do not know if it is legal. Has anyone else had this idea and found out whether it is legal for the 2008 competition?
Julian
Unread 21-01-2008, 17:34
Re: Using Magnets
The rules say nothing about that type of sensor. If you are unsure, I would talk to Q&A. At this point, probably legal if it is under the cost limit. (Note: the Gear Tooth Sensors are magnetic sensors.)
Unread 21-01-2008, 17:42
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Using Magnets
Team 1501 is thinking of using a Mag Lev
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 21-01-2008, 19:47
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Using Magnets
We used a magnetic contact like an alarm system would have two years ago. It worked ok because it would move so fast it would miss it sometimes. It just depends if that affects your application or not.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 21-01-2008, 19:48
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Using Magnets
As far as I know magnets are fine on the robot. The gear tooth sensor supplied with the kit of parts is magnetic and the motors generate magnetic fields while being used. Last year we considered using a magnetic latching system and found nothing against it in the rules.
Unread 22-01-2008, 15:39
Capt. Quirk Capt. Quirk is offline
AKA: Bill Mazzacane
FRC #1704 (Robotic Steelers)
Capt. Quirk will become famous soon enoughCapt. Quirk will become famous soon enough
Re: Using Magnets
Melexis 90217 Hall-Effect Sensor
Short circuit protection
Rotary position gear tooth sensing ability (using a magnet is better)
On-chip 10 bit A/D converter
Self-adjusting magnetic range
High speed operation
No chopper delay
Zero speed detection
No rotary orientation concerns
It is normally pulled high and goes low when it detects a magnets south pole. It should be real easy to watch with the IFI controller.
Unread 23-01-2008, 19:42
FRC #0852
Re: Using Magnets
Thanks Guys. Capt. Quirk showed a sensor that we could possibly use but i don't know if it will work for us. Does anyone else have any ideas?
Julian
Magnets on Robots? Windward Rules/Strategy 3 15-01-2007 17:55
Questions about magnets. Elgin Clock Math and Science 20 15-04-2006 12:21
magnets? ewankoff Kit & Additional Hardware 7 17-01-2005 01:45
Magnets blindguyinanorg Kit & Additional Hardware 2 22-02-2004 13:05
Magnets allowed?¿? Speed1130 Technical Discussion 35 30-01-2004 20:11
