Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Unread 21-01-2008, 17:36
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
IR with Radio/Tether
Hey,
We've got the IR all working and good.
Problem is that when we connect the tether averything works fine, but when connected thorugh the radio the IR does not do anything.
Anyone else has the same problem/knows what the solution could possibly be?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 21-01-2008, 17:42
KDawg's Avatar
KDawg KDawg is offline
"That's not a question"
AKA: Kenny Miller
FRC #1126 (SparX)
KDawg will become famous soon enough
Send a message via AIM to KDawg
Re: IR with Radio/Tether
Are there any lights on the OI or Robot radios when turned on? Where are you connecting the radio through?
1126 TEAM SPARX!!
I am the software team
Unread 21-01-2008, 19:29
Tottanka's Avatar
AKA: Liron Gurvitz
Everything but the IR is working both in Radio and tether...so that will not be the problem..
Unread 21-01-2008, 19:47
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Are you plugging the radio into the right port? That is something that has caused my team problems in the past. Also do you have your radio set up correctly (team number etc)?
Unread 21-01-2008, 22:51
fstumpo's Avatar
fstumpo fstumpo is offline
Question Everything!
FRC #1640 (SAB-BOT-AGE)
fstumpo is an unknown quantity at this point
You might need to wire a competition box. See attached doc.
Problems with tether gburlison Control System 3 13-02-2007 17:22
Programming with Radio Phasmatis568 Programming 22 09-02-2005 23:06
Intermittant control with radio TimeOut Control System 45 15-04-2004 12:00
controlling with the radio Lord Nerdlinger Programming 2 17-02-2004 22:40
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
