Go to Post In Israel we've got the president supporting FIRST and speaking at events, so it's time for you guys to catch up =] - Tottanka [more]
Unread 15-01-2008, 20:25
TheFuhr's Avatar
TheFuhr TheFuhr is offline
Zip Tie Aficionado
FRC #0665 (MAYHEM)
TheFuhr is an unknown quantity at this point
Team 665
Welcome to the MAYHEM style of adapting to the problems that arise. When a leak occurred in the ceiling, for the second time (it has since been fixed with duct tape), it shorted out our florescent lights above the mill. In order to continue building our robot, we needed light by the mill. We used our old battery depletion module to shed some more light in the area.
P.S. We have a lowrider. If only hydraulics were allowed in FIRST competitions...
Unread 15-01-2008, 22:06
Jaybee1405
Posts: n/a
Re: Team 665
haha nice idea..
I hope you guys don't run into any problems going over the two 1/2 in. bumps under the overpasses.
Unread 18-01-2008, 00:35
prometheoid prometheoid is offline
AKA: Ray
FRC #2538 (Plaid Pillagers)
prometheoid will become famous soon enough
Send a message via AIM to prometheoid
Re: Team 665
How big are those wheels? 8"?
Unread 18-01-2008, 08:37
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Team 665
Originally Posted by Jaybee1405 View Post
haha nice idea..
As far as I can tell from the prints on how to make a field, there are not 1/2 bumps all the way across under the overpasses.
Can anyone else confirm this?
Unread 18-01-2008, 09:02
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Re: Team 665
The finish line is flat, however, the line divider creates some small bumps where it is anchored.
Originally Posted by 6.2.3 The LANE DIVIDER
The LANE DIVIDER is attached to vertical posts that are anchored to supporting plates covered by carpet. Note that these plates will create a bump in the carpet approximately 1/2 inch tall, and as a result the surface of the TRACK will not be perfectly flat. ROBOTS must be designed to accommodate these surface variations.
Further discussion
about the finish line being flat.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 18-01-2008, 19:52
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Re: Team 665
They are 10" diameter, pneumatic wheelchair wheels, we chose these for more speed. However, the front wheels are 8" (more like 7.5", but we're saying 8).
We don't think we'll have any problems with the bumps, despite what the picture shows, we have about 1" of ground clearance, so I don't expect anything bad happening.
-Greg
Unread 19-01-2008, 00:36
Jaybee1405
Posts: n/a
Re: Team 665
sorry I meant lane dividers
but yes there are 1/2 inch bumps to anchor the lane dividers down that extend out into the field
but if you're 1 inch off the ground then you should be fine
Unread 21-01-2008, 18:07
TheFuhr's Avatar
Zip Tie Aficionado
FRC #0665 (MAYHEM)
Re: Team 665
Almost Done!
Our drive train is going to be beastly this year.
Unread 21-01-2008, 18:20
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Re: Team 665
Do I really want to know what the really long thing (that I can't imaging fitting in the box) is for? Or why it has long black things (pneumatic tubing?) attched to it?
BTW, its very shiny. (both drivetrain and bot)
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
Unread 21-01-2008, 18:37
TheFuhr's Avatar
Zip Tie Aficionado
FRC #0665 (MAYHEM)
Re: Team 665
That would be latex tubing, giving the catapult action more force when under tension.
When it is completely finished, you will be amazed by how much shinier it will become. I really appreciate your appreciation of shininess, it makes our team's mentality seem more common.
Unread 21-01-2008, 19:07
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: Team 665
I'm not sure if this is your final 'bot but if I remember correctly the gearboxes you have on your drive are from two years ago which I think is illegal.
Unread 21-01-2008, 19:16
Re: Team 665
You are correct, on all but maybe the "final 'bot". Those are '05 or '06 kit trannies which are not legal. Put the Toughbox in and that drive will be legal and still have about the same speed.
Unread 21-01-2008, 19:23
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: Team 665
Originally Posted by TheFuhr View Post
Almost Done!
This looks like a design from 05 =P
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 23-01-2008, 13:04
Caeruleus Caeruleus is offline
Team 665's Resident Woodcutter
AKA: Keehyuk Kim
FRC #0665 (Mayhem)
Caeruleus is an unknown quantity at this point
Re: Team 665
Of course we are OBVIOUSLY going to reuse a design from a previous year.
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
Team in a Box V. 2 : Featuring Team 67 and Team 103 OZ_341 General Forum 7 30-01-2006 16:53
