Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 21-01-2008, 19:24
nukelear1991 nukelear1991 is offline
AKA: Mike Poff
FRC #0858 (Delphi Demons)
Team Role: Tactician
nukelear1991 is on a distinguished road
Programming IR Functions/Commands
Im wondering how do I program the different commands that the IR board is supposed to recieve.I understand how to train the board bt actually programming it confuzzles me a little bit. I also need help setting it up so it will be working.
Thank You,
Nukelear
2009 Lansing District Event Champions
Unread 21-01-2008, 19:42
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Programming IR Functions/Commands
I'm not sure if I understand your question. You never actually program the board itself. You simply train the board and then run PWM cables from the boards various pins to digital inputs on the OI. Then because each button push causes a pin to receive voltage you will be able to do various things based on the state of that pin.
Unread 21-01-2008, 20:17
AKA: Mike Poff
So If I had CMD1 (or w/e) plugged into Digital in I would type
rc_dig_in01 == 1 then
hybrid function
or something along those lines
Unread 21-01-2008, 20:20
Yes I believe that is correct.
Unread 21-01-2008, 20:57
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Hi i was wondering how we can do a multi functional button code. e.g. Command a goes forward, Command b stops etc.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 21-01-2008, 21:05
There is a large section of the rules devote to this subject--I will do my best to summarize, but please read the rules.
You may send up to four distinct commands using the IR remote. You may not send commands involving code (like morse code) or in anyother way attempt to get more than four actions out of your four distinct commands. This is ideally to encourage people to create higher level command structures.
A sample set up might look like this.
Button 1--goes forward 2 seconds
Button 2--turns left 20 degrees
Button 3--turns right 20 degrees
Button 4--Reverse 2 seconds
You may not control your robot based off of a continually held down button.
Does that answer your question?
Unread 21-01-2008, 21:11
MiniNerd24's Avatar
Our remote continuousy pulse too. I forgot to mention that.
Thanks though we will try that idea too.
The system is down.
Commands Barchechath Programming 7 05-02-2007 18:55
Programming the vex microcontroller to respond to commands on the serial port crashoverride02 Programming 1 20-10-2006 14:17
Programming Trigonometric Functions Dan894 Programming 4 14-02-2006 20:27
Functions of '?', ':', and '&' in the C programming language DanDon Programming 8 05-05-2005 09:25
at commands in c++ daroch Programming 1 04-03-2005 01:01
