Go to Post I was thinking (dangerous I know) - EricH [more]
Unread 19-01-2008, 08:27
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Plexiglass Adhesives for electrical box
Our team was thinking about putting our electrical components in a plexiglass box, the only problem we are having so far is that we don't know what adhesives we could use to put them together, could you help us find the best one to use. I thank you many times in advance.
P.S. Sorry if this is in the wrong board
Unread 19-01-2008, 08:59
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Plexiglass Adhesives for electrical box
First of all, don't use plexiglass. It fractures easily, and not permitted on the robot. We use MEK (methyl ethyl ketone) as a solvent glue for Lexan (ploycarbonate plastic). If the part is under stress, we sometimes use machine screws tapped into the joints for extra strength, along with glueing. For a good glue joint, ensure the surfaces are clean and flat, and clamp until the solvent has evaporated, and the joint has solidified. Hope that helps.
Unread 20-01-2008, 02:07
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Ooh, an electronics box, neat. Our team put all of our electronics in a box last year too: http://www.chiefdelphi.com/media/photos/26295
It looked really awesome because everything was all tight and compact in a removable box, but changing things became very difficult because we had to take the whole box out of the robot to fix or change anything. Don't forget to mount the RC so the lights are visible....we mounted the front towards one of the outside faces of our box using standoffs, so you could see it pretty well, but when you wanted to add any PWM cables, you had to unscrew the RC.
Post pictures when you're done!
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 20-01-2008, 02:14
dtengineering's Avatar
AKA: Jason Brett
While I agree with the recommendation to use Lexan over Plexiglass, I am not aware of anything in the rules that would prohibit a team from using Plexiglass if they choose to do so.
Jason
Unread 20-01-2008, 17:54
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
... We use MEK (methyl ethyl ketone) as a solvent glue for Lexan (ploycarbonate plastic) ...
And please be careful using this glue! Read the labels and take ALL of the Safety Precautions. Get the MSDS and really read this one!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 20-01-2008, 18:00
AKA: Alan Bartow
Team Role: Driver
I've definitely been considering Lexan over plexiglass the way it is talked about, and right now it looks life we may be using silicon to put it together and then bending the lexan (maybe). Also there will be two boxes one for the controller at the front of the robot, and then one with everything else at the back.
But i will definitely take what y'all have said into consideration, and will post pics whenever we our done.
Unread 20-01-2008, 18:27
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
superglue works fine( Cyanoacrylate). correct me if im wrong or this is unsafe please.
thanks, vivek
"we don't build robots, we build people"
Unread 20-01-2008, 19:47
DonRotolo's Avatar
Back to humble
FRC #0832
The folks who sell you the plastic can sell you the glue. Basically it is a solvent that melts the plastic.
Cyanoacrylate is OK, but test first on some scraps - certain plastics will craze (spiderweb of fine cracks) from it and lose all strength.
As long as the box does not carry any load, silicone sealer will be fine, BUT remember it really is not that strong.
If you do use MEK, be real careful, especially with the rule "use in a well0ventilated area", that stuff is nasty and breathing it is contraindicated by your operations manual...
Don
Unread 21-01-2008, 19:19
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
......don't use plexiglass. It fractures easily, and not permitted on the robot.....
Need to see the rule number, please. I cannot find it in any FRC document.
Is it just a local "team rule"???
You can cause a lot of confusion by quoting rules that don't exist.
Unread 21-01-2008, 20:52
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Weld-On #16 works for both pexiglass and polycarbonate.
Unread 21-01-2008, 21:12
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
In years past, plexiglass (acryllic) was specifically forbidden. I do not no if this is still the case, but I can not encourage you strongly enough to avoid plexiglass. It shatters under impact!. Lexan (polycarbonate) is impact resistant.
In either case, the joint will be strongest if you have clean straight edges. Consider a pass over a belt sander with fine grit paper to knock down any high spots. (CNC machining would be best, but most of us don't have that luxury.)
Best of luck. (Use Lexan!)
Lee
Mentor - Team 2108
Unread 21-01-2008, 21:25
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
How long ago was that? It wasn't forbidden when I was in FIRST and that's going back four years.
Unread 21-01-2008, 22:21
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
I can not find any rule that said we can not use plexiglass. If anyone knows that this is a real rule let me know. We are a rookie team and would have used lexan if we had to do it again but we already have our electrical board together on plexiglass and have been succesful in drilling and cutting it.
Unread 21-01-2008, 22:44
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
Plexiglass may not be specifically forbidden however it is a very good idea to see if you can replace it with lexan. Even a thin sheet of lexan would be safer for your electronics and its worth the $30-40 to buy a sheet of lexan over the $450 for a new RC or $120 for a new Victor.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Unread 22-01-2008, 01:07
eeeeweeezeee's Avatar
eeeeweeezeee eeeeweeezeee is offline
menace to public safety
FRC #0114
eeeeweeezeee will become famous soon enough
Send a message via AIM to eeeeweeezeee
we use polycarbonate and we use Velcro to stick down components. with the really sticky Velcro a little bit goes a long way, and you can peel up a damaged component and stick down a new one very quickly. we also usually have an access door or a side that comes off that is either hinged with some sort of lock, or an entire side comes off when you un-do some socket-head cap-screws.
EEEEWEEEZEEE
was here
pic: Team 27 Electrical Box Jimmy Holmes Robot Showcase 18 17-02-2006 16:18
pic: Team RUSH 27 Electrical Box austind27 Extra Discussion 20 02-03-2005 19:41
[OCCRA]: Electrical box #1Transgirl1140 OCCRA Q&A 1 24-09-2004 18:54
pic: Team 93's Electrical box CD47-Bot Extra Discussion 9 12-03-2004 09:46
Plexiglass Archon Off-Season Events 6 25-04-2003 11:17
