Go to Post Safety is a practice, not a number. - Alan Anderson [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 22-01-2008, 02:36
Compnerd's Avatar
Compnerd Compnerd is offline
Self-Proclaimed Nerd
AKA: James H
FRC #1444 (Lightning Lancers)
Team Role: Webmaster
Compnerd has a spectacular aura aboutCompnerd has a spectacular aura about
Workshop Connectivity Issue
Our team this year had to rent out workspace. The workspace is much better than the schools classroom we had last year, however, the workshop has no internet connection. The Bread Company (approx. 300 feet away) has offered to let us use their wireless internet connection. However 260 feet is too far for the wireless signal to travel. We are trying to think up of some ideas to be able to be able to extend that range. Some of the ideas that have been mentioned are "Cantennas" which are basically potato chip cans with a wire inside acting as an antenna. Also, i thought about using a "repeater" which would be placed between the workshop and Bread Co. each of these have their advantages and disadvantages. I have done some research, and found that the signal will travel roughly 150 feet from breadcompany. A normal 102.11g router will broadcast 300 feet if outside without walls blocking the signal. The only signal we pick up is the post office's wireless next door, and that's not a possibility to use. Please post with any comments/ideas.
James H. - Webmaster - Team 1444
http://www.first1444.com
If you need any website help send me a PM
Unread 22-01-2008, 02:59
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Workshop Connectivity Issue
If they are in the same building, just wire a long cable over. If that is not a possibility, you may end up buying a net connection.
you could use this as an opportunity to work with a company... i bet you could get a good deal from the connectivity company if you tried.
we were able to get internet in our space by using a CT law in our favor (free internet for educational purposes or something like that)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 22-01-2008, 11:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A cantenna with a reasonably high-gain antenna is a good bet, but it could be pricey. Linksys makes some routers that are compatible with ww-drt firmware that will also allow you to adjust the power output of the router itself - however you will need one on both ends.
It might be cheaper and easier just to get the team to sign up for a couple of months with a broadband wireless card and then run your internet through that. Generally the cost about $59 a month. Have you checked to see if you could sign up for two months of DSL or Cable internet?
Unread 28-01-2008, 19:27
zim2411's Avatar
zim2411 zim2411 is offline
AKA: Peter Harris
FRC #1727 (Rex 1727)
zim2411 is a jewel in the roughzim2411 is a jewel in the roughzim2411 is a jewel in the rough
Is the path from your workshop to the Bread company pretty much line of site?
I have a Linksys WRT54G modded with dd-wrt firmware, and it connects as a client to my friend's network about 300 ft away. I can then hook my laptop or any computer into the router via ethernet and get internet access. The signal strength is about 10-15% but the internet actually works fine. On his end he has a Netgear 802.11n router behind a brick exterior wall of his house. On my end the glass window is the only thing blocking line of sight to where his router approximately is. (some branches kinda hang in the way but not really)
Unread 28-01-2008, 19:49
Compnerd's Avatar
AKA: James H
Yes it is actually. It's 268 feet if you draw a straight line... I used google earth to find that out.. But that's something i may try
Unread 28-01-2008, 20:04
zim2411's Avatar
AKA: Peter Harris
If anyone on your team has a Macbook, ask them to bring it and try and connect. They have utterly insane reception. My same friend sitting in his drive way can pick up an access point about 800 ft away. (that is a stock linksys WRT54G, line of sight to house, but router is on the far side of the house.)
Unread 28-01-2008, 20:28
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Run another wireless router from the bread company to your shop as long as you need it to get enough internet connection to be sufficient in your building.
Unread 30-01-2008, 19:08
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Just bring in a Network Ninja. Steal their bandwidth!
Nah, just kidding. The cantenna idea might work, so try that before resorting to buying a network connection or, worse, buying a Mac and routing ALL networking through that. I'm sorry; but I wouldn't trust website development bandwidth to a Mac's router. (I had a bad childhood experience with a MacinBox in my uncle's basement. The Myst... it was everywhere!)
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Workshop space alexvasile General Forum 15 21-09-2007 19:15
Question about Fisher Price Motor Connectivity: Joobacca Motors 1 05-02-2007 13:24
Wifi/Connectivity in the GA Dome?? Justin Championship Event 24 22-04-2005 15:48
Workshop Kel D Off-Season Events 3 05-06-2003 23:45
