Go to Post I guess that we will just have to live with it, EH!!! :D - Steve W [more]
Unread 18-01-2008, 18:41
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
Analog pin output data
I have an old QuickShot GenX 500 Joystick that I want to use for experimenting with a theory I have. My problem: I can't find the documentation on the analog outputs anywhere. Is there any kind of program or anything that will tell me what pin a signal is being thrown two when you output something?
The reason I want to use this particular joystick is because A. I already had it from years ago, B. It has a "Z" Rotational axis perpendicular to the other two axis.
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 18-01-2008, 21:33
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Analog pin output data
A quick Google leads me to believe that it's a USB device, which means you would have to use the chicklet. I don't think your device is supported.
Either way, I recommend you just plug it in, and use the Dashboard Viewer, with it set to OI mode. Then you can move it around and poke things and see what variables are being used. Unless you're asking something else...
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 20-01-2008, 12:15
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
or, if you don't have the dashboard, just set up some printf()s in the code that tell u the value of the joystick, and if you don't know which variable you want, then print all of them!
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 22-01-2008, 10:23
3DWolf's Avatar
AKA: Jake
Thanks guys. We ended up and did the print spam thing, thanks for the idea. Luckily the Z axis on the joystick outputs directly too _aux! No long and exhausting hack arounds for it.
It's an old version of said joystick, it has serial connector.
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
Gyro Output Data Venkatesh Technical Discussion 1 03-02-2003 21:34
Dutch Pin patrickrd Technical Discussion 5 03-03-2002 12:27
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
