Go to Post Look past the robot. Look past your team. Science and technolgy are studies worth devoting your life too. - KenWittlief [more]
Unread 22-01-2008, 11:29
auditt241 auditt241 is offline
FRC #0241 (The Astros)
auditt241 is an unknown quantity at this point
Mounting a Chain to Frame
I spent forever looking for an answer, but maybe I'm just searching for the wrong things. Anyway, our team needs to mount the end of a chain to some 80/20. Does anyone know any hardware that would allow us to bolt the end of some chain on to some 80/20 securely? Thanks!
Me: "Dude I built a robotic arm today"
Friend: "Why don't you go build a robotic life?"
Unread 22-01-2008, 11:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mounting a Chain to Frame
McMaster-Carr has some, they are called "Roller Chain Attachments"
Unread 22-01-2008, 11:37
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Have you considered screwing a 1/16 or 1/4 piece of flat aluminum to the 80/20, drilling a hole through it, then using a master link or a half link and just putting the pin through the hole in the aluminum?
Unread 22-01-2008, 11:40
Thanks! It's a shame too because we just ordered a bunch of parts from them, and the guy that was supposed to figure all of that stuff out didn't think of it.
Unread 22-01-2008, 12:17
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Are we talking about chain chain or roller chain? If its regular old chain, then a small u-bolt should do the job. If its roller chain, see the above post regarding mcmaster.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 23-01-2008, 18:41
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Last year we needed to do this. We just used a #10 bolt through one of the links into the standard T-nut that come with 80/20. The bolt doesn't fit quite, so you need to very carefully drill out the hole, very carefully cause this can be hard. This method worked great. The connection was more than strong enough to stall the motor and hasn't shown any signs of wearing out yet.
Chain hong12891 Inventor 8 05-02-2007 20:03
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
chain Lake Orion OCCRA 1 30-09-2001 13:20
