Go to Post "well.. I think I underestimated the swine..." -Andy Baker - Joel J [more]
Unread 22-01-2008, 10:33
leobot_792 leobot_792 is offline
FRC #1591
leobot_792 is an unknown quantity at this point
Exclamation steering wheel ???????
Is a steeringwheel possible to use with a robot? If so what kind or brand will work and how can we do it????
Unread 22-01-2008, 10:43
slickwill1675 slickwill1675 is offline
FRC #0247
slickwill1675 is an unknown quantity at this point
Re: steering wheel ???????
leobot_792,
I think this is what your looking for...
http://www.ifirobotics.com/usb-chicklet.shtml
If you already have a USB Chicklet then you need to buy a Logitech NASCAR Racing Wheel for the PC. IFI robotics has a list of all the supported hardware on that page.
Good Luck,
Will
#247
Unread 22-01-2008, 11:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There are lots of ways to get a steering wheel to control your robot....we got an older version of this
http://www3.towerhobbies.com/cgi-bin...I=LXASX2**&P=0
and took out the transmitter board, wired the steering/throttle pots to the OI, and now have an easy way to drive last year's 6WD robot. It did take some work to get the shaft encoders programmed, and some soldering to connect the wires. So you'll learn a lot if you try to do it this way.
but it sure is easy to drive..and you can hold the whole thing in your hand, and easily pull the throttle (it has reverse too, just push the trigger away from you)
Unread 22-01-2008, 11:30
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
you could make your own, i did over the summer. I gutted a joystick and set about attaching a wheel to the Y axis pot and a lever to the X axis pot for throttle. It was quite fun to drive my edgie bot around with it.
Unread 22-01-2008, 11:57
mp.nighthawk's Avatar
mp.nighthawk mp.nighthawk is offline
FRC #1510
mp.nighthawk is an unknown quantity at this point
and also onto thouse ideas if you serch ebay for a serial stearing whell im shure you could find something
have fun building!
it is a very sexy board!
i think i broke it,......
whats smoking?!
Unread 22-01-2008, 12:13
MrForbes's Avatar
AKA: Jim
If you do find a serial steering wheel (or any used item from ebay or elsewhere), make sure it is still available new, so it is a legal COTS item.
Unread 22-01-2008, 12:23
REVving up for a new season
FRC #2848 (All-sparks)
My interpretation is that COTS are only relevant for parts on the robot. Otherwise nobody could use the old flight sticks anymore....
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 22-01-2008, 12:49
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
My interpretation is the same as Greg's. The controls are not included in the Bill of Materials requirements or the cost accounting.
However, the only intrepretation that matters belongs to the GDC. Someone with a Q&A login should ask the question there. I'm suprised no one has yet, as there seems to be quite a bit of confusion regarding the COTS requirement and if it does or does not apply to the operator controls, based on several comments I have seen in different threads.
I'd post the question to Q&A myself, but I don't have a login.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 22-01-2008, 12:54
MrForbes's Avatar
AKA: Jim
The joysticks are KOP items so they need not be COTS.
Unread 22-01-2008, 12:56
in between teams
AKA: Luke Van Oort
<R36> specifically allows unmodified COTS parts from previous robots; if you consider the controls part of the robot, that allows the old, out-of-production CH Flightsticks. Unmodified COTS parts from ebay... I don't know. Definitely a Q&A worthy question. Wheels aren't really that complex anyway; we will probably be building one for testing purposes, if not for the final implementation. I suggest telling a couple of newbies to build one; even if you don't use it, it'll be a great learning experience.
Team 1219: 2009 - Mentor
Unread 22-01-2008, 13:01
MrForbes's Avatar
AKA: Jim
You might want to consider this
"<R13> For the purposes of determining compliance with the weight and volume limitations specified in Rule <R11>, these items are NOT considered part of the ROBOT and are NOT included in the weight and volume assessment of the ROBOT: ...... The OPERATOR CONSOLE.
However, for all other purposes the items listed above are considered part of the ROBOT and must comply with all other applicable rules and requirements. "
Sounds to me like that means that all of the parts used on the robot and the Operator Console must meet the requirements for being COTS or from the KOP.
Q&A should be able to set us straight one way or the other, though.
Steering wheel radicalnerd Technical Discussion 30 31-05-2007 00:56
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
