Go to Post I've been inspired for real engineering during the build season and on the playing field, but the inspiration I found in the pits is often for creative thinking and intuition. - artdutra04 [more]
Unread 22-01-2008, 13:42
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Question Parallel or Series, which is better?
Our team is having trouble deciding which is better.
The strengths and weaknesses of each would be great. (And reasonings for them are also a bonus!) Thanks in advance.
Design. Build. Dew.
Unread 22-01-2008, 13:45
AdamHeard's Avatar
Lead Mentor
Re: Parallel or Series, which is better?
in reference to what?
Unread 22-01-2008, 13:54
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Hah. I saw the title of this thread, and was like.....
Parallel and Serial ports???
Then I saw it was under pneumatics.
Yes, please provide some more information as to the system you are referring to. Always keep in mind the pneumatic guide posted on the FIRST website.
Jacob
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
We need a little more info.......
What are you putting in series or parallel?
batteries?
loads? (resistance?)
I'll take a guess of what you are asking.........
When connecting two batteries in series you are doubling the voltage while maintaining the same capacity rating.
When connecting 2 batteries in parallel you are doubling the capacity (amp hours) of the battery while maintaining the voltage of one of the individual batteries
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 22-01-2008, 15:59
mrbob1000's Avatar
mrbob1000 mrbob1000 is offline
I feel smarter already!
AKA: Stephen Johnston
FRC #2377 (CCompany)
mrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to behold
Send a message via AIM to mrbob1000
i think they mean pneumatic tanks and/or pistons.
if you put the tanks in series or parallel doesn't matter.
if you put pistons in parallel then yo get the same pressure on both calenders.
Unread 22-01-2008, 16:07
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
from my experience it doesnt matter if your pneumatics system is in seris or parallel...
Unread 22-01-2008, 17:04
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
When charging the tanks it would not matter. You will be restricted by the tubing. Discharging the tanks may be a different story. If you wanted to fire four cylinders at the same time as fast as possible, would it make sence to have the tanks in parallel? It seems as though if you feed four valve/cylinder combinations through four pieces of tubing with each one connected to a different tank verses a single piece of tubing feeding air through a single valve teed to four cylinders that the volume of air would be less resticted. Has anyone ever tried this? The amount of brass, valves and regulators of doing this would take a large piece out of your weight budget. I am not sure if this type of setup is legal. It is just an idea at this time.
Unread 24-01-2008, 08:27
diesel's Avatar
FRC #2077
Sorry for not being clear.
Yes, I am talking about pnuematic tanks.
We have one piston on our robot.
Will putting the tanks in parallel provide more force?
Will putting them in series make the pressure last longer?
And any other facts would be great.
Thanks.
Design. Build. Dew.
Unread 24-01-2008, 08:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The air from the tanks all has to go through one regulator, so it really does not matter how you connect the tanks....things will be moving slowly if the cylinder is large diameter.
Unread 24-01-2008, 10:42
Generator of Entropy
FRC #2973 (The Mad Rockers)
Thanks.
1) Putting the tanks in parallel does not provide more force. Force in your piston is generated by the area of the piston times the pressure downstream of the regulator, which is the lesser of the regulator setting (60 psi default, lower if you dial it down or use a second regulator) or the pressure in the tanks (when the regulator no longer has to "regulate" a higher pressure down to its setting). The pressure is the same in both tanks (and all the tubing up to the regulator) regardless of whether it is a series or parallel connection because it is really just one big volume of air connected by tubing. Since you are drawing air out of this volume through the same size tubing, the remaining air is able to stabilize/equalize to the same pressure regardless of where you remove air from the storage volume.
2) By similar reasoning, the pressure will last the same amount of time for series and parallel, because you are storing the same volume of air either way, and removing the air at the same rate either way.
Unread 25-01-2008, 17:50
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Speaking of parallel:
Is it legal to use two regulators in parallel to provide 60 psi to pistons from the 120 psi tanks? Twice the flow would be available...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 25-01-2008, 18:07
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
I thought about doing that on our robot, but I don't think it's legal.
<R98> “Working” air pressure on the ROBOT must be no greater than 60psi. All working air must
be provided through the Norgen adjustable pressure regulator, and all other pneumatic
components must be downstream from this regulator.
A pressure gauge must be placed
adjacent to the pressure regulator and display the downstream pressure.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 25-01-2008, 18:12
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Thanks.
OK, the simple answer is ... it depends.
It depends on what is the controlling orifice (what has the most restriction or lowest CV) as to whether series or parallel is better. squirrels' answer assumes that the regulator is the controlling orifice, which is generally not true. Usually the valve has the controlling orifice.
Changing the path at the controlling orifice (IE splitting the flow path and having it run through 2 valves) will garner you the biggest bang for the buck.
I believe that the regulators are a 'bleed' type which means that when the output overpressurizes (goes over the setpoint pressure of the diaphram) the regulator bleeds off the excess pressure through a pressure relief vent. This would mean that if both regulators weren't set EXACTLY at the same pressure (no easy feat) then one would continue to supply air while the other would be venting it, and that would tax your on-board compressor.
___________________
- Tennyson, Ulysses
Unread 25-01-2008, 18:57
We're splitting hairs here, but in reference to his question - should the tanks be in series or in parallel, the fact that the valve is the controlling orifice has nothing to do with the answer to that question. By the rules, all the flow from the tanks has to go through a single tube into a single regulator and then out to the system. Regardless of whether you put one valve or 10 valves downstream, the rate at which air will go through that one tube and one regulator is not dependant on whether the tanks are in series or parallel. The storage volume will discharge at the same rate.
Unread 25-01-2008, 19:11
Los Frijoles's Avatar
Los Frijoles Los Frijoles is offline
Stormin' Mormon
AKA: Kevin Cuzner
FRC #2062 (C.O.R.E.)
Los Frijoles has a spectacular aura aboutLos Frijoles has a spectacular aura about
Send a message via AIM to Los Frijoles
All that tanks really are is very large diameter tubing. Since Air is a gas, it will flow freely to fill up the entire space that it is given, so placement of the tanks does not have a serious effect on the way the air flows. Only in applications where the movement of air is critical and at high velocity like pneumatic potato guns does tank placement matter.
Community Of Robotic Engineers 2062
Blender totally pwns 3DS Max...
My life is here and here.
Cuznersoft Hardware and Software Development
Non Frc: Electrical question series and parallel Tri_Lam General Forum 14 06-03-2007 19:16
non frc question: electrical series to a parallel??? HELP Tri_Lam Math and Science 0 02-03-2007 16:56
which is better keagara Chit-Chat 2 02-02-2006 14:42
Which Show is better?? mtaman02 Televised Robotics 22 27-09-2003 18:14
