Re: Our Power Distribution
Very nice!
Some things we can't tell from the picture: Along with the concern about being able to plug in the cables, you might want to make sure the motor connections at the Victors are not too close to something, or it will be kind of hard to work on. And just to double check...at the distribution block, did you make sure to strip 5/8" of insulation off the wires, and tighten the set screws firmly? If you dont strip off the full 5/8" and insert them fully into the block, then you could have problems with the wires falling out. |
| Power Distribution Block | kE7JLM | Electrical | 4 | 17-01-2008 08:48 |
| Power Distribution Block.. | beemgruem | Electrical | 21 | 11-01-2008 08:11 |
| Power distribution Block? | Pontchartrain | Electrical | 3 | 27-01-2006 07:30 |
| Power Distribution Requirements | kham | Electrical | 2 | 14-01-2006 12:35 |
| Power Distribution | xxmaddjxx | Electrical | 13 | 30-01-2005 00:43 |
