Go to Post Everybody "cares about the robots" - otherwise we'd be doing science fairs. - Taylor [more]
Unread 10-01-2008, 01:44
CraigHickman
Posts: n/a
Re: what Chain size and tensioner to use for the drivetrain
Originally Posted by Darunada View Post
the chain doesn't eat the HDPE away?
The reason I ask is because the chain ate away a good half inch into our robot when some bolts rattled loose on a pneumatic tire, causing it to expand and push the sprocket (and thus, chain) into the frame.
For non idler chain runs, we use Glass infused Delrin (use masks when machining this crap, it's NASTY to your lungs!), which held up incredibly well, and never wore down during our whole season.
Unread 10-01-2008, 01:45
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Best not to go with Chain tensioner it is more friction and more work for your CIMS. Just make the chain as tight as possible and don't worry if it take you a full day to mount the wheels. It is one of the most important parts.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 10-01-2008, 01:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This is poor advice.
Any properly designed chain tensioner will not rob your drive of any power.
Every drivetrain should have some provision for tensioning chain. If you don't, it will eventually stretch enough to be too loose, even if you calculated the exact center-center distance to allow you to use a whole number of links.
2001-2004: Team 100
2006-Present: Team 254
Unread 10-01-2008, 02:10
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
It has work for us for two years...
Team 842 Programmer
Pictures at:
Videos -
Unread 10-01-2008, 02:16
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
This is true.
However, will it really exaggerate itself over the 3-9 days that I'm guessing most teams compete (that's 1-3 events)?
Not that I advocate not having a tension system. I still stand by sliding motor mounts.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 10-01-2008, 03:13
Cory's Avatar
AKA: Cory McBride
Originally Posted by Otaku View Post
This is true.
We put hundreds of hours of drive time on our robots. Some teams clearly put a lot less on theirs.
A blanket statement that tensioners are unnecessary is never a good thing, imo.
2001-2004: Team 100
Unread 10-01-2008, 11:22
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Making the roller chain as "tight as possible" would be a larger load on the motors than a properly tensioned drive train.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-01-2008, 11:53
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
I have had some robots that functioned fine for a whole season, while never having to adjust the chain. I've had others that had to be constantly adjusted. Sometimes you can get away with not having tensioners, but it's like playing a game of Russian Roulette with your drivetrain. It's better to come up with a tensioning solution (HDPE, idler sprockets, sliding motor/wheel mounts) than to risk having your drivetrain fail in a critical situation because the chain got too loose.
Jeff Waegelin
Unread 15-01-2008, 17:20
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
Where can we get HDPE and do we have to make the tensioners or do they come pre-made?
Unread 21-01-2008, 11:44
artdutra04's Avatar
Check out page 3498* of McMaster-Carr's catalog for the HDPE (high density polyethylene) solid rod between about 1" and 3" diameter.
* Just type in 3498 in the search box on McMaster.
Art Dutra IV
世上无难事,只怕有心人.
Unread 21-01-2008, 12:32
DonRotolo's Avatar
Back to humble
FRC #0832
Best not to go with Chain tensioner it is more friction and more work for your CIMS. Just make the chain as tight as possible.
Properly tensioned chain is far better than "as tight as possible". This puts unreasonable loads on the components, and actually reduces its ultimate strength since the load is oscillatory and subject to fatigue.
The fraction of a watt consumed by a tensioner can be measured, but you'd never notice it.
Maybe doing it wrong works for you and your team, and that's cool for you, but that doesn't make it good engineering practice.
Don
Unread 21-01-2008, 15:04
DPTeam270Driver's Avatar
DPTeam270Driver DPTeam270Driver is offline
Deer Park Driver
FRC #0270 (Falcon X)
Team Role: Driver
DPTeam270Driver will become famous soon enoughDPTeam270Driver will become famous soon enough
team 270 always had a problem w/ chain tensioning
if u would like to be cheap, you can use zip ties to tension the chains
or this year we found cim motor tensioners in one of the old KOP bins, we just made plates and they are great. they provide constant tension and are easy to maintain
Unread 21-01-2008, 19:00
Dick Linn's Avatar
no team (Synergy)
HDPE is readily available in cutting boards, laundry detergent bottles and other things marked with the #2 recycling symbol with the HDPE or PE-HD printed below the triangle. Think milk jugs, eh?
If you keep your chain runs short, use quality components and align them and occasionally lubricate the chain, you shouldn't have a lot of chain tensioning problems. I agree that if your design allows the primary drive/gearbox to be adjusted or shimmed slightly, it makes life simple. One time, we needed a tensioner for a long chain run, so we cut a guide groove in some skateboard wheels and used them as rollers. Worked marvelously, and cost virtually nothing. The only other time, we stuffed a narrow piece of HDPE into a channel in some 80/20, as the chain needed to go over a rather misplaced structural rail in its path. frtgtgf'ikb n
(The last comment is from our kitten, who jumped up on the laptop twice and managed to shut everything down a few minutes ago. Thank goodness Firefox cached everything... I wouldn't want to deprive y'all of these words of wisdom amongst the cussing...)
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 22-01-2008, 14:42
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Where did you guys get your Pps? We're thinking about using it for tensioing our drive chain. Thanks.
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
What size breaker should I use for the RC? Excelsior Electrical 4 18-01-2006 07:34
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
