Go to Post Now Dave, before you get all snarly about these- remember, I still have the button maker... - MissInformation [more]
Unread 22-01-2008, 15:38
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
PID without the D
so I looked around a bit for this and I can't seem to find a way to do this on the multiple white papers that are posted. So my question is, how do I use the proportional and Integral parts of the theory with out the derivative part of it.
I know how to do them individually but have no idea on how to combine ay of these aspects to do anything meaningful.
Thanks in advance for any help that can be provided
Unread 22-01-2008, 16:09
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Re: PID without the D
Well if you have a full PID loop up and running, then just set the D gain to zero and you'll be running PI, you'll need to retune the loop though.
Otherwise, if you have them running individually but not together, just take the output of P and I and add them together for a simple PI loop, once again you'll have to retune it.
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Unread 22-01-2008, 16:11
If you know how to calculate the P, I, and D errors, combining them is easy. Just use a different gain constant for each and add the outputs together.
For example output = Kgain * Kerror + Igain * Ierror + Dgain * Derror.
Once you have code that does all three, an easy way to disable any of them is to set the gain to 0 for that one.
Unread 22-01-2008, 16:20
Joohoo's Avatar
FRC #0340 (G.R.R.)
on that note, the PID loop, how fast do I really need it. Is the normal 26ms loop fast enough? or does this need to be faster?
Unread 22-01-2008, 16:26
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: PID without the D - implementation of the I
When implementing the integral part, you can start by just adding or subtracting a constant value (start with one) and adding the integral part to the Proportional part. So, suppose you have a 5V analog potentiometer that is connected to an arm. The target or set point you want is 4V which corresponds to about 818 counts or units on the 10 bit A/D. If you are presently at 3V or about 614 counts or units, you want to move towards 818 counts. So, Error is 818 minus 614 = 204 counts. Multiply 204 by let's say 10 percent . To speed up calculation , use multiply by 26 and divide by 256 (26/256 is about 10 %).
So, (204 times 26)/256 is 20.7. With roundoff you will get 20 counts. Next, since PWM units are scaled 0 to 255, which is 1/4 range of 0-1023 a-d units, you will need to rescale (divide by 4) the 20 counts output by 4 to get 5 counts. This will be what you add to the present value you are already outputting to the PWM (which is scaled zero to 127 for one direction and 127 to 254 for the other direction). So if your present PWM output is 150 counts, you will add 5 counts for the proportional part of the 26.2 msec loop you are in. Next, since you are below your target, add 1 PWM output unit to the 150 counts for the integral portion of the PI gain. Remember this is all happening 38 times per second, so the numbers you add for the Proportional and Integral part can be small. Hope this sheds some insight into one way of making your PID work for you.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 22-01-2008, 16:27
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
a) We've always done the PID loop in the 26ms loop, and it's worked for us.
b) Since you can't update the PWM outputs any faster[*] than every 26ms, I don't see how running your PID calculations any faster would be of help to you.
Why do you want to do just a PI loop? I've heard of people using just P, or PD, but never PI.
[*] Actually, you can update your PWM outputs faster, if you use PWMs 13-16 and your own pwm generation functions (or one from a non-IFI library)
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 22-01-2008, 16:37
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
I would think that doing a PI would be really unstable. The D part has the effect usually of dampening the I since the I will always overshoot the goal. Of course the instability will dampen itself over time because of friction in the system but I would agree that I have never seen a PI loop. Plenty of P+D and P-D and just P loops but never a PI loop.
What exactly is your reason for not using the derivative part of the loop?
Unread 22-01-2008, 16:57
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Alex.Norton View Post
Plenty of P+D and P-D and ......
Not meaning to side track here, but that is what I'm going to do.
P+D and P-D, which is correct? Or should I ask, how do I determine which to use?
Unread 22-01-2008, 17:06
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Actually PI control loops are fairly common. If you have a situation where proportional control alone works well, it's common to add an integral term with a low gain to remove the fixed error inherent with proportional control. Here is example integer PI code from the camera tracking code:
// x-axis/pan tracking code
// save the current pan servo PWM value into a local
// integer variable so that we can detect and correct
// underflow and overflow conditions before we update
// the pan servo PWM value with a new value
temp_pan_servo = (int)pan_servo_position;
// calculate how many image pixels we're away from the
// vertical center line.
pan_error = (int)T_Packet_Data.mx - (int)Tracking_Config_Data.Pan_Target_Pixel;
// Are we too far to the left or right of the vertical
// center line? If so, calculate how far we should step
// the pan servo to reduce the error.
if(pan_error > (int)Tracking_Config_Data.Pan_Allowable_Error)
// calculate how far we need to step the pan servo
servo_step = pan_error / (int)Tracking_Config_Data.Pan_Gain;
// Due to rounding error in the division calculation above,
// the step may be calculated as zero, which will make it
// impossible to converge on the target when pan_error is
// smaller than Pan_Gain. To get around this problem, we just
// test for the zero case and set the step size to one.
 if(servo_step == 0)
    servo_step = 1;
elseif(pan_error <-1* (int)Tracking_Config_Data.Pan_Allowable_Error)
 if(servo_step == 0)
    servo_step = -1;
else
// if we've fallen through to here, it means that we're
// neither too far to the left or too far to the right
// of the vertical center line of the image and don't
// need to move the servo
servo_step =0;
// signal that the pan servo is on target
Tracking_State += STATE_PAN_ON_TARGET;
// add the step to the current servo position, taking into
// account the direction set by the user in tracking.h
temp_pan_servo += ((int)Tracking_Config_Data.Pan_Rotation_Sign * servo_step);
// check the pan servo PWM value for under/overflow
if(temp_pan_servo < (int)Tracking_Config_Data.Pan_Min_PWM)
 temp_pan_servo = (int)Tracking_Config_Data.Pan_Min_PWM;
elseif(temp_pan_servo > (int)Tracking_Config_Data.Pan_Max_PWM)
 temp_pan_servo = (int)Tracking_Config_Data.Pan_Max_PWM;
pan_servo_position = (unsigned char)temp_pan_servo;
// update pan servo PWM value
Set_Pan_Servo_Position(pan_servo_position);
-Kevin
Kevin Watson
http://kevin.org
Running the robot without a tether Hiromi Technical Discussion 3 05-10-2007 08:37
PID How to hold an arm in a fixed position without a locking gear box Ian_Xodus General Forum 29 28-01-2007 08:50
PID without a Ph.D. Joe Johnson Programming 3 07-02-2006 17:37
Emergency: PID with Wheels Off the Ground Rick TYler Programming 9 07-02-2006 11:37
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
