Go to Post Ah, to be a teenager and know everything again. - Alan Anderson [more]
Unread 22-01-2008, 15:57
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Errors compiling Kevin's new code (pragmas)
hey guys, trying to compile kevin's code (made changes to default_routines only), getting some errors in MPLAB.
258: warning [2002] Unknown pragma 'tmpdata'
249: Error [1020] Unexpected input folowing 'interrupt'
364: warning [2002] Unknown pragma 'tmpdata'
Can anyone help?
Also, what exactly is a pragma? I've never dealt with them before, so help is greatly appreciated.
PS- If I comment off the three lines that cause errors, it gives me
442: Error [1111] undefined label '_FPFLAGS' in '_startup'
Team 2052- Knightkrawler
Mentor and volunteer
Unread 22-01-2008, 16:04
Re: Errors compiling Kevin's new code (pragmas)
Are you compiling his code for the 3.x compiler with the 2.4 compiler?
Unread 22-01-2008, 16:15
AKA: Bryan
That's probably it. I thought we had updated it, but apparently not. I'll post back here if that doesn't fix it.
Unread 22-01-2008, 16:57
AKA: Bryan
Okay, that fixed the original issues.
Now however, when it gets to the last linking step (COFF to HEX), it pops up "failed to load file xxxxx.cof."
The COFF file is right there in the folder, and it can find it when it is cleaning up the files when I try to build it again. Any ideas?
Update- After done building, the output screen occasionally returns "Error: bad magic number in Coff file xx/xx/autonomous.o"
Unread 22-01-2008, 17:07
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
On the project check the build options to make sure they are the right paths.
Clean sometimes will get something via a different path that the linker won't see.
Unread 22-01-2008, 17:15
AKA: Bryan
Which paths?
The linker and lib paths are the defaults (C:\mcc18\[lib or lkr]). I tried to manually set the output directory to the correct directory, but it changed nothing.
Unread 22-01-2008, 17:22
Kevin Watson's Avatar
La Caņada High School
FRC #2429
If the "magic number" is different across the project it means somewhere you've got a piece of code compiled with the wrong compiler version and the linker gets unhappy. My guess is that you're trying to link everything together with the 3.1 tools, but have the wrong version (i.e., 2.4) of the ifi_frc.lib file.
-Kevin
Kevin Watson
http://kevin.org
Unread 23-01-2008, 15:58
AKA: Bryan
I downloaded the simple C18 3.0 code from your site, so I assume the ifi_frc file is up to date.
If it helps at all, if I download the hex file that appears (but is definitely not complete) to the bot, all the OI's pwm, realy, and switch lights turn on.
Finally, printf almost always returns one of a few errors, no matter what I'm printing. Any suggestions as to why? Not entirely sure of specific errors, I'll edit if I come across one again.
Unread 25-01-2008, 15:15
AKA: Bryan
Sorry, missed the editing window.
Anyways, where can I find the update ifi_frc.lib file? I have ifi_frc_8722.lib and ifi_frc_8520.lib, but no ifi_frc.lib, ifi_frc.lib.
I checked kevin's page, and the ifi robotics page, but couldn't find it.
Thanks!
Unread 25-01-2008, 17:36
Spider-Man's Avatar
Spider-Man Spider-Man is offline
Curling Rocks
AKA: Adam Jacobson
FRC #0467 (DTB/Shrewsbury Colonials); #0034 (Rocket City Robotics)
Spider-Man has a spectacular aura aboutSpider-Man has a spectacular aura about
The numbers in the file correspond to a specific version of the robot controller. The current controller version as of 2006 is 8722, which is the one you want.
In the Library Files area of your project you want the downloaded ifi_frc_8722.lib compiled with C18 3.0+. Also, make sure that your linker script is the 18f8722.lkr.
Hope that helps.
Student [2000 - 2001] Team 34 Rocket City Robotics
Plays Well With Others
2000 VA - Delphi "Driving Tomorrow's Technology"
2000 CMP - Top 5 Autodesk Visualization
2001 TX - Regional Finalist
Mentor [2004 - 2005][2007 - ????] Team 467 Shrewsbury Colonials (nee Duct Tape Bandits)
We Not Me
2004 LI - DaimlerChrysler Team Spirit
2004 LI - Website Design
2005 MD - Delphi "Driving Tomorrow's Technology"
2007 MA - Johnson & Johnson Sportsmanship
2008 CT - Judges' Award
2008 PA - Judges' Award
2010 MA - Judge's Award[/size][/font]
2012 DC - Chrysler Team Spirit[/size][/font]
2012 DC - Regional Winners[/size][/font]
2013 MAWO - Engineering Inspiration[/size][/font]
Unread 25-01-2008, 22:14
AKA: Bryan
Yes, we are using the 8722 lib and lkr files.
Unread 31-01-2008, 12:50
FireJet FireJet is offline
AKA: Jero Sutlovic
FRC #2386 (Trojans)
FireJet is an unknown quantity at this point
I'm having the same problem with the new default 2008 code. Everything compiles fine, but I keep getting the error that it "Failed to load project.cof". I've made sure that the library and linker include paths were right, and using the correct linker/library versions.
Problem with Kevin's code Tottanka Programming 5 04-11-2007 13:32
Disabling Vex compiling errors jcsymmes Programming 2 03-06-2006 01:54
Kevin's Code? winners Programming 5 27-01-2006 16:32
Question about kevin's code ImmortalAres Programming 3 23-06-2005 11:13
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
