Go to Post I guess my point is, let's see how it plays out before we condemn it to failure. - Chris Hibner [more]
Unread 22-01-2008, 16:00
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Issues with our code
Originally Posted by Ryan O View Post
Hi,
We are also having problems with our gyro. I plug it in to port one, as init, start it, ect. It gives zero for awhile, then starts increasing and doesn't stop, even if the gyro isn't moving. Any help would be great.
Make sure it's plugged into an analog port rather than a digital port.
The gyro returns the rate of rotation as an analog value - where no rotation is will return a value around 512 (center).
You can easily test if the gyro is working by running easyC and opening the Online Window. Load the Online code into the robot and look on the screen at analog port 1. Now you should be able to twist the gyro (or robot if it's attached) and see the analog values jump from a centered value around 512 to either smaller or larger numbers for left and right twists. Remember, the value will only change while the robot is moving since it is measuring rate of rotation, not the heading.
Brad Miller
Robotics Resource Center
EasyC master code issues Joe G. Programming 2 14-12-2007 11:28
Code Flashing Issues bluenp Programming 4 07-11-2007 23:43
need help with our default code coolguybigt Programming 14 19-02-2007 10:17
Issues with encoder code jgannon Programming 7 26-03-2006 15:12
Issues with MPLAB 7.30 gnirts Programming 4 25-01-2006 22:57
