Re: Using a different gear tooth sensor
Good job with the research it is very much appreciated. Did you do any research or do you have any speculation about why one is good and one is bad? Is there any known part of the circuit that is bad on one and not the other?
Just try to get to the root of the problem. Thanks. |
| Gear Tooth Sensor | marco_alchemy | Electrical | 7 | 06-02-2008 09:54 |
| A different kind of gear tooth question | Semicolon | Electrical | 3 | 12-01-2008 16:24 |
| Gear Tooth Sensor? | Raikon | Kit & Additional Hardware | 3 | 09-02-2007 16:40 |
| Gear Tooth Sensor | nukem | Programming | 9 | 04-02-2006 20:21 |
| Gear Tooth Sensor | Talha | Electrical | 1 | 23-01-2006 21:29 |
