Go to Post The world is run by those who show up. - apalrd [more]
Unread 10-01-2008, 14:12
jfrank's Avatar
jfrank jfrank is offline
FRC #2668
jfrank is an unknown quantity at this point
Question command listfor c???
does anyone have a command list for C or C+ programming
Unread 10-01-2008, 15:21
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: command listfor c???
A command list won't make you a programmer... you'll have to learn the syntax of the languages as well.
There are lots of free resources, including an "Introduction to C Programming for FIRST" available here:
http://www.usfirst.org/community/frc...nt.aspx?id=482
What place are we at? ... TODAI!
Unread 11-01-2008, 17:01
tagger tagger is offline
FRC #2357
tagger is an unknown quantity at this point
I'm 16 years old and I barely know any visual basic code plus i've only read about the first chapter in C++ programming for dummies. I just recently finished a program that will enable us to detirmine the ratio for the speed of the robot compared to the difference between the stop speed (127) and the speed we want the robot to go. Also I am going to make another program to find the degrees the robot turns based on the difference between the two engines. What is a command list? I seriously don't know and would like to be able to program after were past the testing phase where the programming is easy to figure out like trigonometry. If anyone wants the code I made to test these variables or just use it as a template for their own testing code, E-mail me at JeffreyHB123@hotmail.com.
I don't know what im doing very well,
Jeff~
P.S. This is not the person that uses the account, this is just another person on his robotic team. RAY-PEC For The Win.
Unread 11-01-2008, 17:08
Mib Mib is offline
AKA: Aaron Clay
FRC #1741 (Red Alert Robotics)
Mib is on a distinguished road
Send a message via AIM to Mib Send a message via MSN to Mib Send a message via Yahoo to Mib
There is no "command list" for C or C++. It's pretty simple though. I would start out getting Kevin's code for a base, then modifying it for your needs. As far as resources for C, cprogramming.com is a good start.
Aaron M. Clay
Programming Consultent
www.GameCopyWorld.com
amclay (@) purdue.edu
Unread 22-01-2008, 13:16
jfrank's Avatar
FRC #2668
Thanks
Unread 22-01-2008, 13:19
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Do you have a Linux computer? If so, just try going into terminal and typing "help". The core language of the Linux operating system is C, as opposed to Windows' "A++" script and Mac's "Applescript", which are just disguises for Linux-based commands.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Unread 22-01-2008, 13:40
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
This is completely untrue and will not help you in any way with FIRST programming. Most OS's are written in C/Assembler. Just find some online C resources to get you going. Typing help in a terminal will do nothing short of showing you a list of BASH help commands for the terminal and will get you nowhere with programming, C, or FIRST.
Unread 22-01-2008, 14:32
CRBreingan CRBreingan is offline
FRC #2180 (Zero Gravity)
CRBreingan is an unknown quantity at this point
Send a message via AIM to CRBreingan
i understand what jfrank was asking. I too was looking for a list of commands.
Is there really nobody that has made a list of the available functions in the FRC library? I think it'd be a nice reference to have. I 'd do it myself but i can't read the binary in the .lib files... .
Brad Miller did a hell of a job with the WPILIb. If you want to be able to reference a table of functions i would suggest going with WPILib. All the functions have definitions and tell you how to write the argument in the API.h file. It's wonderful to be able to know what exactly you're calling from the library. If you want to check out WPILib go to http://users.wpi.edu/~bamiller/WPILib/
Unread 22-01-2008, 16:23
The list I think you're looking for is in the .h files.
Unread 22-01-2008, 17:36
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I use a C syntax chart for quick reference. Two that I like are:
C/C++ from gbookcards.com I got this for every programmer on the team.
This one is free C reference PDF
And I use the API.h file from WPILib as the other reference.
Unread 22-01-2008, 19:39
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
O'Reilly Pocket reference books are really nice. I have several of these, and some cheat sheets with my computer at all times. They're great for when I can't remember some little detail.
C Pocket Ref
C++ Pocket Ref
Eric Haskins KC9JVH
Unread 22-01-2008, 19:58
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
This sounds like a job for easyC! Intelitek wrote easyC to teach students how to program in C by displaying syntax correct code in the right hand window. You should be able to find the cd in the KOP and then check out the tutorials in the help file.
Unread 22-01-2008, 20:16
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Here's two threads I setup at our forum that lists a few resources for learning C, and programming FIRST robotics.
http://naples1551.theiforum.com/firs...rces-t113.html
http://naples1551.theiforum.com/c-resources-t75.html
I hope these help.
Loader Protocol: Command 09 Astronouth7303 Programming 1 28-01-2007 01:02
Make all command pmzq Programming 3 24-01-2006 16:16
Servo command confusion?!?!?!?! [527]phil Programming 9 15-07-2005 20:10
Run command... frightening archiver 2001 1 24-06-2002 03:37
