Go to Post Students, mentors, schools, corporations, teams, and communities - they are all critical to the success of FIRST. . - dlavery [more]
Unread 22-01-2008, 20:24
leftylink's Avatar
leftylink leftylink is offline
Code always works the first time!!!
FRC #1318 (Issaquah Robotics Society)
leftylink is on a distinguished road
Eclipse troubles - Nothing to build...
Hey everyone. The software group from my team is attempting to set up Eclipse with Shtylman's plugin to work with our FRC code, but we've run into difficulties and would like some help.
We've got Eclipse and the CDT, and have also downloaded Shtylman's MCC18 Eclipse Plugin. We create the new project and then paste our old code into the project folder in the workspace. We can see the files listed in the Project Explorer. Then we Build Project, assuming it will work, but the console displays "Nothing to build" and we don't know how to proceed. Can someone help?
As of now we're going to try reinstalling the MCC18 compiler itself and see if that helps matters...
Edit: Bleah, now it looks like Eclipse can't find Java! Don't know if reinstalling MCC18 did something funny to our PATH...
Edit: We reinstalled Java, and now building gives us "Exec error: launching failed". This is getting frustrating...
Your help would be appreciated greatly...
Issaquah Robotics Society 1318
2009 Galileo Division Semifinalists - Great way to finish off my FIRST career and high school.
2009 Oregon Regional Champions - Great job, 1983 and 2635!
Unread 22-01-2008, 21:40
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Re: Eclipse troubles - Nothing to build...
We've been using Eclipse following the guidelines that Brad Miller documents at this site: http://users.wpi.edu/~bamiller/WPILib/
We're also using WPILib, which works well with learning C from EasyC. We're able to cut and paste code from EasyC right into Eclipse.
I'm not familiar with Shtylman's plug-ins but if you hit a dead end, give the link above a try, it worked for me.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 22-01-2008, 21:44
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
I had a problem kinda like. I just moved the FRC_Defualt.hex out of the code directory. Then it worked.
AdamBots.com- Winner of 7 Best Website Awards!
Unread 22-01-2008, 22:01
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
I've seen this problem a lot and it can be caused by a few things. I'm using a slightly different mcc18 plugin for eclipse, but make sure you've installed mingw(http://sourceforge.net/project/showf...?group_id=2435) and added it to your path(C:\MinGW\bin).
Unread 23-01-2008, 01:15
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
Most likely you are missing the "make" utility from your path.
quickly Googling I located a download for it.
http://www.steve.org.uk/Software/make/
You need to put the make program somewhere in your path where the system can find it.
Unread 25-01-2008, 14:24
leftylink's Avatar
We had MinGW, we tried downloading make for Windows from shtylman's link... we wrestled with it for a while and decided that instead of trying to wrestle with this to get it to work, we would use Eclipse for working with the code and then use MPLab for when we need to compile. It's a really imperfect solution, but it's the best we can do.
Any teams build two robots to practice with after build season. (6 weeks) GVDrummer General Forum 42 24-01-2008 21:34
"Full screen mode" in Eclipse/Easy Eclipse Kelly Programming 0 15-07-2007 16:37
Do Nothing Autonomous epsilon Programming 7 01-04-2003 23:28
THREE-NOTHING!!!!!!!!!!!!!! Justin 188 Chit-Chat 2 15-05-2002 22:43
