Go to Post Maybe we should have some safety training before and during build instead of just having flyers at our pit. Hm... - JaneYoung [more]
Unread 22-01-2008, 20:28
psniffler psniffler is offline
FRC #2240
psniffler is an unknown quantity at this point
Rack and Pinion/Motors and servos
How have other teams done rack and pinion in terms of motors? Is there a way to turn a motor into an accurate enough servo? Or how else could we implement it?
Unread 22-01-2008, 22:31
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Rack and Pinion/Motors and servos
Yes you can use a PID control loop or springs to recenter the steering wheels.
Unread 24-01-2008, 22:43
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
king of l337 would you mind explaining in detail about PID control loops and things like that and how we can achieve that? thanks it's our rookie year and we've been able to manage but there are still some things we're unsure.
Unread 24-01-2008, 22:46
Jaybee1405
Posts: n/a
We're using a form of this with a potentiometer and a globe motor.
Unread 24-01-2008, 22:55
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Could you go into more detail?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 25-01-2008, 00:05
shock190 shock190 is offline
AKA: Andrew
FRC #0190 (Gompei and the H.E.R.D.)
shock190 is an unknown quantity at this point
Well, heres the very short version of a PID control loop.
First off, you need the steering motor hooked up to a potentiometer or something similar (a 10 turn pot should be more than enough for most rack and pinion setups). The PID loop takes the value that you want the pot to read (corresponding to the position of the rack and pinion), and the value the pot is actually at. Then the three parts kick in:
P- proportional control. This simply takes the difference between the desired value and the actual value, then multiplies this by a constant that you pick through estimation and testing. This essentially compensates purely based on distance from the desired location. It is also important to implement a dead band of values to prevent the motor from overshooting the intended target and then oscillating around it for a long time (the constant also plays a big part in this).
I- integral control. This is somewhat more challenging to implement (it requires an array setup in C, or something similar). It takes the last X number of error values (you choose X), sums them to determine the overall error, then multiplies this by a different chosen constant. This is extremely useful when inside the deadband of the P control, as it sums the errors, then applies a light correction to decrease the sum of the errors (move the error to zero SLOWLY).
D- derivative control. This is about the same difficulty level as integral. It uses the same array as the I control, but takes the derivative (or rate of change) of the last few error values, and scales the speed (with yet another constant) in relation to that. So as the actual value approaches the desired, the motor speed slows down.
After all of these functions (or just P, PI, PD...), you sum all of the control loop outputs together, and apply that correction to your motor. I'm sure other people on here are much more capable of explaining the source code to make one work well (I'm more of a mech myself), but thats the general theory behind one.
Team 190 - Building the ridiculous since 1992
2008 BAE Granite State Regional Leadership in Controls
2008 Silicon Valley Regional Creativity Award
2007 World Champions (with 987 and 177)
Unread 25-01-2008, 00:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We set up this prototype steering mechanism, it worked ok...as well as can be expected for a 2wd Ackermann steering robot, that is.
http://www.chiefdelphi.com/forums/sh...95&postcount=3
We're going skid steer 6wd with fancy steering wheel control programmed into it instead. But it was a fun experiment to build this robot and drive it around.
Unread 25-01-2008, 16:16
DarKCroNo's Avatar
FRC #2670
Thanks so much! however if it is possible would you mind explaining in a bit more detail? is the PID a programming code? and how would the robot controller whether the rack and pinion has gone either left or right? Thanks again!
Rack & Pinion SHS Blue Devils General Forum 5 12-01-2008 17:59
Servos controlling camera and purple screen ryan_f Programming 6 17-01-2006 23:21
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
