Go to Post One career isn't really more prestigious than another; not in and of itself. More than anything it depends on what you do with it. - Matt Leese [more]
Unread 22-01-2008, 20:45
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
Exclamation No Feedback via Programming Port
Hey guys,
I'm trying to use kevin's 3.0 code. I am using the proper version of MPLAB (8) and C18. The code compiles just fine. When I use ifi loader to download the code, though, I get zero feedback from my printf calls. They are in the right place btw. When I hit the reset button on the oi or rc I get a message like >ifi and an initialized... message. This was what one normally gets with no printf statements. I then tried a HEX file from 2007's season compiled with 2.4 and IFIs default code. This time I got plenty of feedback. My only question is how do I resolve this issue with kevin's code and the latest compiler (3.0)?
Unread 22-01-2008, 21:09
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: No Feedback via Programming Port
Hmm, can you upload the file so the CD task force can take a look?
This is probably obvious but make sure the serial cable remains plugged in...
In the meantime, try copying and pasting the IFI warm-up printf call into Teleop() and commenting out all others.
Is it ONLY your printfs that don't work? That is, your robot still does the hokey pokey and everything, it just isn't showing serial feedback?
P.S. I'm in Tacoma! See you at PNW? Tacoma for sure though!
What place are we at? ... TODAI!
Unread 22-01-2008, 21:29
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by manderson5192 View Post
Hey guys,
If you're seeing the "IFI User Processor Initialized ..." message, everything should be functioning because it's generated by a printf() located at the bottom of the Initializtion() function. If you get stuck, send me your code and I'll have a look.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-01-2008, 21:07
AKA: Matt Anderson
Thanks for the help guys. We resolved the problem by including \r and \n at the end of our printfs. I guess the compiler prefers that we not be lazy and only include \n.
User input via serial port AJBelayer FIRST Tech Challenge 2 14-12-2005 18:54
Programming via Edubot Joshua May Programming 11 29-04-2004 19:18
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Programming Port I/O MikeDubreuil Programming 4 10-02-2003 17:07
Programming Port Steven Carmain Programming 18 23-01-2003 21:36
