Go to Post I've managed to convince my wife that Valentine's Day is February 24th. :) - dtengineering [more]
Unread 22-01-2008, 22:34
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Global Variable Placement
I've tried to insert global variables in various places in Kevin's code only to get stack overflow, code errors (RC), sytax errors, compiler crashes and general system crashes. Where do you all put your global variables. I'm interested in global only. I'd like to minimise passing information between functions. Thanks
Unread 23-01-2008, 00:50
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Global Variable Placement
A good practice is to declare a variable outside of any function and then declare the variable as "extern" within the associated header file. So for example, at the top of teleop.c I declare a variable:
// this allocates memory
unsigned int foo;
Then in teleop.h I declare the variable again with the keyword extern:
// no memory is allocated, but lets the compiler know the name (foo)
// and type (unsigned int), and that it is located in another source file
extern unsigned int foo;
Then include teleop.h at the top of each source file that needs to use foo. The line will look like this:
#include "teleop.h"
-Kevin
Kevin Watson
http://kevin.org
Global news tonight Mark Rozitis FIRST In the News... 3 08-04-2008 21:24
GTR on Global news! Mark Rozitis General Forum 26 08-04-2007 21:00
Global Constants Ryan Cumings Programming 17 08-02-2004 19:05
Global Variables, anyone? Darkman_X000 Programming 3 05-02-2004 22:11
