Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 27-01-2007, 17:00
Joel J's Avatar
Joel J Joel J is offline
do you..
Solenoids + 20A breakers.
I was going to wire each of the needed solenoids on our robot this year to a spike, then each spike to its own 20A breaker, but then I saw a diagram on (the real) page 26 of the robot manual. It had the RC going to one 20A breaker, the compressor going to the other, and then Spike Relays going to a 20A breaker. So that leaves me with a question: are we allowed to wire multiple spikes to one 20A breaker? That is, 7 solenoids connected to 7 spikes, and then one 20A breaker taking all seven of the spike power connections.
Let me know. This would actually be really awesome.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 27-01-2007, 21:51
Electrical Engineer
Rookie Year: 1995
Re: Solenoids + 20A breakers.
Joel,
From an electrical engineering perspective, wiring multiple Spikes to one 20A CB is OK as long as the total load is less than 20A. However, the 2007 Robot Power Distribution Diagram shows individual CBs to each Spike...
I would like to see someone post this question to the FIRST Q&A for a ruling clarification.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 23-01-2008, 00:51
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
I have a sort of related question: Am I allowed to wire two solenoids to the same spike relay if I need the two solenoids to act simultaneously?
I know the rules say I have to wire each electrical load to one Spike/Victor, but can I wire multiple loads to the same spike?
Unread 23-01-2008, 00:55
Yep
<R56> Each power regulating device (Victor speed controller or Spike relay) shall control one and only one electrical load (motor, actuator or compressor). Multiple low-load devices (e.g. pneumatic valves) may be connected to relay modules (but only one motor may be connected to each relay module).
There is also no rule about how many PWM Y-cables you can use. One Y-end to each spike (up to two) and the single end to the PWM output on the RC, and you're good.
Last edited by EricH : 23-01-2008 at 01:12. Reason: Only read the first part of the rule...
Unread 23-01-2008, 01:00
AKA: artqny
Just to clarify, when it says
Does "relay module" mean the Spike relay? And if so, then it is ok to connect two solenoid valves to one Spike, right?
Unread 23-01-2008, 01:06
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
Why not plumb two actuators to the same solenoid if they need to go off at the same time?
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 23-01-2008, 01:11
I was wrong about what the rule said...
The Spike relay is the only allowed relay module. Therefore, two would be legal.
But Eric's solution would be more elegant. One solenoid, a tee shortly afterwards, and then the tubing to the actuator.
Unread 23-01-2008, 01:14
AKA: artqny
That's a really good point, but I guess two separate solenoids would use two separate tubes, so the actuators can fill with air twice as fast. Otherwise, we can use one solenoid, but then both actuators would have to fill through one tube.
Please correct me if I'm wrong because we haven't tested this yet.
Unread 23-01-2008, 03:16
AdamHeard's Avatar
Lead Mentor
yes, two separate systems should fill faster. Depending on what your using it for, and what size cylinder, it may not make a difference though.
Unread 23-01-2008, 11:22
AKA: artqny
ok. thank you everyone for your help.
Solenoids Rohan_DHS Rules/Strategy 2 04-02-2006 00:11
20A breaker sources Rickertsen2 Electrical 2 24-02-2003 21:06
Our 20A and 30A and 40A breakers . . . Frank(Aflak) Technical Discussion 8 01-02-2003 08:36
Solenoids archiver 2001 9 23-06-2002 23:47
Solenoids turbidum Rules/Strategy 1 09-01-2002 21:26
