Go to Post A video is worth 30,000 words a second. - Thromgord [more]
Unread 23-01-2008, 08:24
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Can you use this?
Originally Posted by Steve_Alaniz View Post
You can indeed use that sensor... but let me also suggest
http://www.maxbotix.com/uploads/LV-M...-Datasheet.pdf
I've ordered one of these to test but it appears the analog output can be applied directly to an analog input. No interrupt routine. At least that's how I read the Datasheet. I'll verify this in a day or two.
Best wishes
Steve
INDEED!!!
This is the exact model in which we used last year. I clicked on your link and was SO surprised to see a picture of what we used staring at me.
Indeed, you simply need to apply power, ground, and you can use the AN pin directly to the analog input on the RC. Simply get the analog input in your program, and you have a number (0-255 I believe, but I think its more like 12-220 or something.)
Ironically, I just tested ours out last night (we have 2 currently, perhaps we will be ordering more.
Jacob
I can read this....can you? Wayne Doenges Chit-Chat 2 22-03-2006 14:49
Can we use the 2005 RC for this year's robot? DemonYawgmoth Control System 6 13-02-2006 17:34
can you use Carbon Fibre? Greg Perkins Technical Discussion 9 05-02-2004 14:15
Can you use other tubing? Skabana159 Pneumatics 2 06-02-2003 22:04
