Go to Post That seems like a pretty cool idea! Who'da thunk o' dat?! :rolleyes: - dlavery [more]
Unread 23-01-2008, 09:42
Synchronizing with 26.2 ms communication
I'm having difficulty trying to tune a velocity PID loop, and I've come to the conclusion that part of my problem is that the PWM outputs aren't changing at a predictable time relative to the PID sample time. They're not even changing at the same rate.
Is there a way to detect when the User and Master CPUs have exchanged their information? Or does EasyC even use the same "every 26.2 ms" scheme that the IFI default code has? So much is hidden behind the scenes and I don't know how to peek behind the curtain.
EasyC is easy for simple stuff, but I'm apparently fighting it when I want to try more advanced coding. I can't believe that I have to jump through so many hoops to do things that aren't predefined, and I have to think I'm just failing to see the "right" way.
Need Help With Maplab C programming on serial communication loveheb3 Programming 0 04-06-2007 21:24
Labview and communication with peripheral device help jaijaidin LabView and Data Acquisition 3 26-01-2007 19:17
Serial Communication Problems with LabVIEW FRC Toolkit Jon236 LabView and Data Acquisition 1 28-12-2006 11:57
Methods of communication???? aviv Chairman's Award 3 18-02-2006 20:10
organized way of communication with FIRST? archiver 2001 0 24-06-2002 04:20
