Go to Post There is no rule that specifically states that you must obey the law of physics during the competition. This may be an oversight. - bmather [more]
Unread 04-10-2006, 16:23
travmizer's Avatar
travmizer travmizer is offline
Head of Programming
AKA: Travis Schmidt
FRC #0617 (Springer Express)
travmizer is an unknown quantity at this point
Send a message via AIM to travmizer
Unhappy Program doesn't effect robot
Ok, now my computer loads programs. The default loads, but only makes one wheel and our gatherer work. When I try to load my program, however, The robot is completely unresponsive of the joysticks.
This is my code from user_routines :
void Default_Routine(void)
/*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
* This maps the joystick axes to specific PWM outputs.
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
pwm05 = p1_x;
pwm06 = p2_x;
pwm07 = p3_x;
pwm08 = p4_x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
/*---------- 1 Joystick Drive ----------------------------------------------
* This code mixes the Y and X axis on Port 1 to allow one joystick drive.
* Joystick forward = Robot forward
* Joystick backward = Robot backward
* Joystick right = Robot rotates right
* Joystick left = Robot rotates left
* Connect the right drive motors to PWM13 and/or PWM14 on the RC.
* Connect the left drive motors to PWM15 and/or PWM16 on the RC.
// pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
// pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
if (p1_sw_trig == 1)
pwm03 = 200; // turn on the shooters
pwm04 = 200;
if (p2_sw_top == 0)
relay1_fwd = 0;
relay1_rev = 0; //no gather movement durring aiming
pwm08 = 120; //closed
if (p2_sw_trig == 1)
pwm06 = p2_x/4; //pan
pwm07 = p2_y/4; //tilt
else
pwm06 = 127;
pwm07 = 127; //NOTE NOTE! this is for the auto aim code
else
pwm08 = 50; //open
if (p2_sw_top == 1)
relay1_fwd = 1; //with both tops down, activates gatherer
relay1_rev = 0;
else
relay1_fwd = 0;
relay1_rev = 0;
else
pwm01 = p1_y; //again, make a #define, probably pwm_1
pwm02 = p2_y; //Also a #define, pwm_2, make sure p1 joystic is on right
if (p1_sw_top == 1 && p2_sw_top == 0)
relay1_fwd = 0;
relay1_rev = 1; //rev gatherer
else if (p1_sw_top == 0 && p2_sw_top == 1)
relay1_fwd = 1;
relay1_rev = 0;
else
relay1_fwd = 0;
relay1_rev = 0;
Also, when the terminal window opens, it reads <IFI> and thats it. (Unless it's the default code, and then it only reads the information for the joystick in port one
ANY HELP??? PLEASE???
Isaac Asimov once said:
If knowledge can create problems, it is not through ignorance that we can solve them.
Unread 04-10-2006, 17:23
Fuzzy's Avatar
Fuzzy Fuzzy is offline
AKA: Mark Hawthorne
FRC #0011 (Mount Olive Robotics Team); FRC #0190 (Gompei and the Herd)
Fuzzy is a jewel in the roughFuzzy is a jewel in the roughFuzzy is a jewel in the rough
Send a message via AIM to Fuzzy
Re: Program doesn't effect robot
Are you sure that all the PWM wires are connected properly in correspondence with the program(s)?
Unread 04-10-2006, 17:36
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
Did you try inserting printfs for the joystick values (including buttons), to make sure the robot is getting the joystick input?
printf("%d\t%d\t%d\t%d\n", p1_y, p2_y, p2_sw_trig, p2_sw_top);
Is everything plugged in (the motors)?
I'm not sure if it was a problem with copying, but there's no ending curly brace for Default_Routine.
Oh, also, a few other things, that probably aren't causing your problem, but might cause other problems:
(In the code, I changed all "x == 1" to just "x" and "x == 0" to just "!x". It's still exactly the same.)
		if (p2_sw_trig)
			pwm06 = p2_x / 4; //pan
			pwm07 = p2_y / 4; //tilt
That will cause PWMs 6 and 7 to always have a value from 0 to 64, depending on the joystick value (0 to 255). Never mind if that's what you were trying to do.
	if (!p2_sw_top)
//some code here...
	else
//more code...
	if (p2_sw_top)
//even more code...
If you're pressing down p2_sw_top, both what is in the else and what is in the if (p2_sw_top) will execute. This probably won't cause problems, but it's just sort of redundant.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Unread 04-10-2006, 20:07
Make doubly sure the call to Default_Routine() is not commented out. (If you're starting with the 2006 code with camera support, it is unless you changed it.)
Unread 05-10-2006, 06:58
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Right, It was commented out so people testing camera code didnt have there robots motors turn on and start causing havoc. Check into that.
Unread 23-01-2008, 10:05
Cesar Cabrera Cesar Cabrera is offline
FRC #2567
Cesar Cabrera is an unknown quantity at this point
How many Joistick can I use in the competition...
Unread 23-01-2008, 10:24
ctclass ctclass is offline
FRC #2389
ctclass is an unknown quantity at this point
can anyone help explain rewriting the c programming were a rookie team struggling with it
Unread 23-01-2008, 10:50
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Lots of people in here will help you. Ask a specific question and someone will give you an answer.
Steve
Unread 23-01-2008, 10:52
FRC #2389
how to wire the pressure switch right for our nuematics
Robot doesn't drive straight bush Control System 14 09-02-2006 00:00
How to program Hall Effect sensors. chantilly_team Programming 1 17-02-2005 14:08
How to keep a program running at a school which doesn't get it? Jimmy General Forum 9 03-04-2003 10:08
Minor Problem, our robot DOESN'T work! Cobra Motors 1 15-02-2003 14:43
Robot reset on OI doesn't work Carl Owenby General Forum 1 07-02-2003 07:23
