Go to Post Its not how much knowledge you have, its how much you want to learn. - tennispro9911 [more]
Unread 23-01-2008, 11:56
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
Re: taigene motor shaft
The main shaft is 11mm round and the easist method of attachment is; drill your pulley to 11mm (slightly smaller than 7/16) and then use a 3/32 roll pin to secure it to the motor shaft.
Unread 24-01-2008, 17:11
wildabyss wildabyss is offline
wildabyss is an unknown quantity at this point
A large portion of the shaft has a rounded rectangular shape. Is there any easy way to use that?
Taigene Window Motor Information CoupeSprinter Motors 4 29-01-2008 20:27
Taigene Window Motor Specs master_nickz General Forum 0 22-01-2008 15:53
Taigene Motor Specs Guy_E Motors 7 21-01-2008 03:25
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
