Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Unread 23-01-2008, 13:14
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Help with automatic relay control
Forgive me if this is answered somewhere else -- I looked and could not find.
I am trying to get a relay to automatically fire forward when the analog values to a pwm are in a range around nutral. I put an if statement in with an assignment specifying the condition I want and it works, but will not change states when when the joystick is moved out of the range. I tried adding an else if statement after, I tried a while loop, no good???
Any suggestions -- I know it is something simple I am missing.
Unread 23-01-2008, 13:32
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Help with automatic relay control
If you post your code, we can tell you what the problem is. If I understand what you are trying to do correctly, it should look a little like this:
if (pwm_val > (127 + deadband) || pwm_val < (127 - deadband))
relay = rev; // out of neutral condition
} else
relay = fwd; // in neutral condition
Unread 23-01-2008, 14:43
DRH2o's Avatar
AKA: Dan Waters
That is the first thing I tried, but the relay will not change from the first state it goes to.
I will try to post some code when I get to that computer. It is done in easyc though -- I might just try to put in some user code.
Thanks
Unread 23-01-2008, 15:11
AKA: Dan
EasyC also visualizes as straight C code so you can post that. It could also be that your joy sticks are out of trim and moving them is not taking them out of your deadband.
Unread 23-01-2008, 15:21
DRH2o's Avatar
AKA: Dan Waters
I thought that also, so I did a print to screen and they show the value change.
Unread 23-01-2008, 18:13
DRH2o's Avatar
AKA: Dan Waters
Dan,
Thanks for the help. I got it working. I do not know what was wrong, but I redid it ( replaced || with && ) and it works great. By the way -- this is for an automatic brake ( using a bicycle disk brake acuated pnumatically ) for our arm. I think it will work great now. Thanks !!!!
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Help: IFI loader not communicating with control unit red_alert_13 Programming 9 20-01-2006 17:30
using SPIKE relay module with Fisher Price motors 1574aviad Motors 4 27-01-2005 01:49
We need help with joystick control Team ICE #1611 Control System 4 24-01-2005 15:57
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
