Go to Post At least I can appreciate the humor in this LOLCODE; it isn't funny when our our robot goes backwards in hybrid mode - sgreco [more]
Unread 23-01-2008, 14:11
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: New C18 3.0+ Compatible FRC Code
I'm having a variety of problems, with the new code(http://www.kevin.org/frc/ifi_frc_sensor_30.zip), and the old encoder code (http://www.kevin.org/frc/frc_encoder.zip).
First off, I'll talk about the problems we were having with frc_encoder. When I had MPLAB 7.20 installed and was using v2.4 of the C18 compiler, everything compiled, and the encoders worked great on the robot. Here was the problem... there seemed to be about a 1/2 second delay between the robot receiving data from the OI, so I would move a joystick, then it would take 1/2 a second for the motors to start moving. I would release the joystick, and it would take 1/2 a second to stop (I almost had a bad incident with our new 80lb robot running me over).
Okay, now for the 3.0 compatible code.
I have MPLAB 8.00 installed and version 3.10 of the C18 compiler.
I can compile the code as it is downloaded no problem, but when I try to initialize encoder 1 and encoder 2 using the code where i take out the //, it fails at the link step:
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - could not find definition of symbol 'Initialize_Encoder_2' in file 'C:\Robot Code\2008\ifi_frc_sensor_30\teleop.o'.
Errors : 1
If I comment out "Initialize_Encoder_2" it will say the same thing about encoder 1.
Is my MPLINK out of date, since it says 2006?
Here are some snapshots of MPLAB with my horrible hand-eye coordination with my trackpad:
Name:	build failed.PNG
The other 4 errors are with this part of code:
	// Remove the // below to initialize encoder #1
	 Initialize_Encoder_1();
	// Remove the // below to initialize encoder #2
	 Initialize_Encoder_2();
//Skipped a bunch of code here to save you time reading this.  The code exists in my version.
	if(i == 37 && j >= 191)
		Encoder_Count = Get_Encoder_1_Count();
		printf("E1=%d\r\n",(int)Encoder_Count);
		Encoder_Count = Get_Encoder_2_Count();
		printf("E2=%d\r\n",(int)Encoder_Count);
	/*	Encoder_Count = Get_Encoder_3_Count();
		printf("E3=%d\r\n",(int)Encoder_Count);
		Encoder_Count = Get_Encoder_4_Count();
		printf("E4=%d\r\n",(int)Encoder_Count);
		Encoder_Count = Get_Encoder_5_Count();
		printf("E5=%d\r\n",(int)Encoder_Count);
		Encoder_Count = Get_Encoder_6_Count();
		printf("E6=%d\r\n\r\n",(int)Encoder_Count); */
Hopefully this gives you enough information to solve my problem.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
