Go to Post I even have a t-shirt that says "Actually, I -am- a rocket scientist" :) - dlavery [more]
Unread 23-01-2008, 16:58
bizarospooky bizarospooky is offline
FRC #2642 (Falconaters)
bizarospooky is an unknown quantity at this point
Mapping Spikes
Sorry if the solution to this is posted somewhere else, I couldn't find it anywhere though. Baisically I am trying to get a spike to respond to the joystick, only thing is I am getting a compiler error of Compatabible Scalar something.
The code I am using is
if (OIToRelay(1, 1, 1, 1) ==1)
//do this
What did I do wrong here? Also, tried assigning it to a variable, that didn't work either, type mismatch (couldn't figure out the type of variable it was)
Unread 23-01-2008, 19:42
Re: Mapping Spikes
So far as I can tell, the OIToRelay() function does it all for you. It does not return a value.
Unread 23-01-2008, 21:00
Re: Mapping Spikes
heh ya, I went back and just tried OIToRelay alone it worked yayy
Mapping FIRST Teams Rob2713g General Forum 26 05-01-2008 00:49
Mapping the controller? greenmachine07 VEX 1 07-12-2007 00:04
Concept Mapping Eugenia Gabrielov Chairman's Award 1 30-01-2005 17:28
Default mapping relay questions Jared Stofflett Programming 1 25-02-2004 19:06
Mapping Buttons to PWMs actorindp Programming 9 10-02-2004 11:11
