Pause a piston?
I was charged with the job of stopping a pnumatic piston in the middle of it's stroke. I first thought of getting both sides of the solenoid to fire at once and realized that it wouldn't work.
Can I take two single throw solenoids and have them act against eachother in the middle of the stroke? I haven't tried it yet and need ideas. If anyone has tried this let me know! __________________________________________________ _______________ cliff451 |
Re: Pause a piston?
It's a 3-position valve. SMC has them in the same series as the kit of part valve, only you need the center closed version. |
Re: Pause a piston?
last year we used a double solenoid on a five port valve with a closed neutral position.
the 5 ports are for: air supply output 1 (extend) exhaust ouput line 1 output 2 ( retract) exhaust output line 2 Last edited by Hito Seika : 01-23-2008 at 05:23 PM. Reason: opps sent before finished!! |
Re: Pause a piston?
Re: Pause a piston?
You can also run the vent valve on the first solenoid to another solenoid. That way you can control direction with the first, and start/stop/pulse whatever with the second. It is not the most precise system but has worked for me before on a previous team.
Re: Pause a piston?
Re: Pause a piston?
You can tie two cylinders together, fire one for half way both for full stroke. Much easier, precise and reliable.
This is also a good way to make the stroke lengths you need that are not legally available. Last year we made a 14" stroke this way. |
| spring piston | Matt21q | General Forum | 2 | 02-02-2007 11:44 PM |
| spring piston? | Matt21q | Technical Discussion | 2 | 02-02-2007 05:02 PM |
| Piston question | Spiffizzle | Pneumatics | 3 | 01-10-2007 09:17 PM |
| [FVG]: Pause during Build | Mike Ciance | FIRST-related Organizations | 4 | 01-12-2005 07:28 PM |
| Stopping a Piston... | Dan 550 | Technical Discussion | 7 | 02-02-2002 11:36 AM |
