Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 23-01-2008, 17:10
cliff451 cliff451 is offline
FRC #2077 (Kettle Moraine Robotics)
cliff451 is an unknown quantity at this point
Pause a piston?
I was charged with the job of stopping a pnumatic piston in the middle of it's stroke. I first thought of getting both sides of the solenoid to fire at once and realized that it wouldn't work.
Can I take two single throw solenoids and have them act against eachother in the middle of the stroke? I haven't tried it yet and need ideas. If anyone has tried this let me know!
__________________________________________________ _______________
cliff451
Unread 23-01-2008, 17:13
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Pause a piston?
cliff451
What you are looking for is a double valve, with a center CLOSED port.
It's a 3-position valve. SMC has them in the same series as the kit of part valve, only you need the center closed version.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-01-2008, 17:20
Hito Seika's Avatar
Hito Seika Hito Seika is offline
aka Garrett
FRC #1225 (Amperage Roboticcs)
Hito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these parts
Re: Pause a piston?
last year we used a double solenoid on a five port valve with a closed neutral position.
the 5 ports are for:
air supply
output 1 (extend)
exhaust ouput line 1
output 2 ( retract)
exhaust output line 2
Sorry about my spelling ….I’m a horrible speller
Last edited by Hito Seika : 23-01-2008 at 17:23. Reason: opps sent before finished!!
Unread 23-01-2008, 17:23
Re: Pause a piston?
Thanks a ton, I'll check that out
Unread 23-01-2008, 17:29
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: Pause a piston?
You can also run the vent valve on the first solenoid to another solenoid. That way you can control direction with the first, and start/stop/pulse whatever with the second. It is not the most precise system but has worked for me before on a previous team.
Unread 23-01-2008, 17:32
Re: Pause a piston?
Thats a good idea too! I can actually try it!
Unread 23-01-2008, 20:52
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Pause a piston?
You can tie two cylinders together, fire one for half way both for full stroke. Much easier, precise and reliable.
This is also a good way to make the stroke lengths you need that are not legally available. Last year we made a 14" stroke this way.
spring piston Matt21q General Forum 2 02-02-2007 23:44
spring piston? Matt21q Technical Discussion 2 02-02-2007 17:02
Piston question Spiffizzle Pneumatics 3 10-01-2007 21:17
[FVG]: Pause during Build Mike Ciance FIRST-related Organizations 4 12-01-2005 19:28
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
