Go to Post Whether we realize it or not, we've all been touched by the works of Dr. Kamen - through his TED talks, through his research and scores of publications in pediatric oncology, or perhaps more directly through his daughter. What an incredible life, what an incredible legacy. - Taylor [more]
Unread 23-01-2008, 17:42
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
SMC single acting solenoid
i cant find which each port is for. can someone help me
Unread 24-01-2008, 00:18
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: SMC single acting solenoid
FIRST consult the pneumatics manual.
The SMC valves:
P port: air supply (not the band)
A port: One outlet
B port: The other outlet
EA: Exhaust port
EB: Exhaust port
The exhaust ports don't need to be connected to anything. The outlet ports you connect to your air cylinder. The P port you connect to your working pressure source.
Last edited by TubaMorg : 24-01-2008 at 00:18. Reason: Typoed pneumatics yet again
SMC Solenoid Vendor? sircedric4 Pneumatics 1 17-01-2008 11:30
single solenoid seanl Pneumatics 4 18-02-2007 02:32
Need instructions for SMC Single/Double solenoid WHou Pneumatics 5 29-01-2005 08:17
Using SMC Single Selenoid Valve from last year? Sachiel7 Pneumatics 3 20-01-2005 21:31
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
